Results 14 to 20 of 20
    Huntinwalkerstyle, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Further infractions may result in loss of posting privileges.
    Jul 2012
    With the pitch on the fan, that's looks like it should be an 825 rpm motor, is it?
    I will have to check. To my knowledge, all parts are original from when it was installed when the house was built, with nothing replaced (12 yr old unit). The fan does work, and works well - this noise does not happen all the time. As described in earlier posts, this occurs randomly and clears up, and the whole unit works - until it doesn't.
    I would shut the whole unit down and keep it off until the tech comes out. The problem is that the last time I did this, when he came out the unit turned on fine, and he wasn't able to diagnose anything wrong. I did not have this recording last time, so I will have to play it for him the next time I call him out. Not sure if he will be able to diagnose based on a video and a working unit - as pros, would you guys be able to work with a customer who has this issue?
    Tallahassee, FL
    Tell your tech to check one thing first
    and I hinted to what Mr bill posted.
    And you will have the mysterious problematical issued.
    Jan 2012
    WEST COLUMBIA S.C.
    High or low pressure switch cutting condensed unit off either because of a leak or high head. Not enough info.
    Jul 2012
    Quick update - finally got it fixed, turns out the capacitor needed replacement. It sporadically did not provide enough for the fan to start, in turn leaving the compressor on, making that noise? I think that makes sense, if I remember correctly from what the tech said.
    Anyways, appreciate everyone's help here. Great thing you guys are doing, helping us non-experts in AC.
    Jul 2012
    i have seen
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, questions, or commentary in other peoples threads here. Please apply to the AOPC today, thank you.
    captaincompressor, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
