Results 1 to 13 of 20
    Jul 2012
    A/C condenser turns off randomly
    I am having a repetitive problem with my upstairs A/C unit. It is a ~12 yr old York HLRA048S06D 4-ton 10 seer (?) unit. When it works, it blows crisp cool air in the 100+ temps we've been having here in TX. When it doesn't, the interior fan continues to turn on when needed, but the outside condenser unit does not turn on, and the upstairs does not cool. For the last week, it seemed to be limited to nighttime when it shut off, but this weekend, it was off for long periods during the day as well, turning back on randomly. I noticed this weekend as well, in the mornings when I turned it on manually to check, the fan was not spinning and there was a buzzing sound coming from the unit. I left it on, with the interior fan blowing and the condenser not on. Later on though, it started to cool once again.
    I had an A/C technician come out to check on it in the afternoon, but by the time he came, it started working again, and as it was blowing cold air he could not diagnose anything wrong. The condenser fan spins freely, no breakers are tripped. He didn't go upstairs into the attic to check on the furnace, was there anything else he should have done? Am I able to bring in a technician again even though it's random when it goes on or off?
    Dec 2010
    Palm Beach,Fl.
    The buzzing sound is a solid clue. A good technician can usually nail an intermittent issue down through a handful of checks. Blowing cold air is not a diagnosis. Sounds like there are several things that he should have done that didn't happen. Definitely get another tech to take a look at the system. Next time you find the unit inoperable, turn off the T-stat. You may be damaging very expensive components that can easily be saved.
    Quote Originally Posted by k-fridge View Post
    The laws of physics know no brand names.
    Jul 2012
    Thanks, I have a home warranty so I plan on having someone different come out to diagnose. Is there anything specific they should be looking for, with an intermittent buzzing noise? Everything's intermittent which adds to the frustration.
    Jul 2012
    One week later and while it has been shutting off more often, it is still random. I did capture the buzzing/screeching noise - I wonder if any pros here might recognize what it could be. My home warranty company is not allowing me to use another tech (unless I pay another service fee), so I'm stuck with the original one for now, and I wonder if he can diagnose based on this.
    http://www.youtube.com/watch?v=EJp8Q...ature=youtu.be
    Houston,Tx.
    Internal relief is giving your compressor a stroke, don't run it without the fan turning, you will just cause more damage.
    Apr 2012
    winnipeg
    hello the condenser fan is not running....... why would you let the poopr compressor run with no fan.....make no sense
    Jul 2012
    That's just it - it makes that noise, stops, then works fine with the fan on later on. This doesn't always happen when it comes on, only some of the time. Other times, it doesn't make that noise, it just doesn't turn on when the t-stat turns on.
    Is that noise for sure the compressor?
    Dec 2010
    Woodbridge Twp, NJ
    SHUT IT OFF!!!!!! It's crying for help!
    Every customer you take for granted today will be someone else's tomorrow.
    Apr 2012
    winnipeg
    get the fan working........ its gonna blow up soon
    Tallahassee, FL
    Looks like they have installed a incorrect fan motor. Imo.
    Apr 2012
    winnipeg
    a heat pump..... its a 100 outside everywhere....... oh i see it thinks its winter...lol
    Huntinwalkerstyle
    Additional infractions may result in loss of posting privileges.
    Your post has been deleted.
    Houston,Tx.
    With the pitch on the fan, that's looks like it should be an 825 rpm motor, is it?
