Results 1 to 13 of 15
    Jun 2012
    Rockledge, Florida
    I can't find 4" filter return grills
    I have a 4 ton Carrier central A/C heat pump with two (2) 20x20 return grilles. Each one holds a typical 20"x20"x1" filter. Yes, I use the high-end 3M filters that get virtually everything. Even when the filters are clean, they slap in pretty hard when I pull them out and release.
    I've seen 4" deep filters of the same size and I'd like to replace my existing set up with two of them. Would it be a good idea or would the extra air volume reduce the evaporator's ability to remove moisture?
    Would it be a good idea for the tech to reduce the speed of the fan motor if I get the 4" filters? Perhaps I can get the same air volume with less power to the fan motor and save on my electric bill.
    Suggestions???
    Cal
    Jim, there are filters manufactured 4" deep with a 1" x1" lip around the 4 sides. They fit in a conventional filter grill and protrude inwards 4". Check the web. I'll post something on Monday if you have no answers from others by then.
    Dec 2010
    Quote Originally Posted by Jim In Florida View Post
    Suggestions???
    What size is the duct that goes to the 2- 20" x 20" filter grilles?
    Jun 2012
    Rockledge, Florida
    Quote Originally Posted by George2 View Post
    Both filters goes to a big framed-in box that's under the air handler. It's in the garage. I guess somebody had the foresight to realize that 20x20 filters are much easier to find than a single 20x40.
    Somebody here mentioned a 4" deep filter that has a ridge to let it fit in the existing filter box??? I did a quick keyword search and all I saw was regular filters and didn't see this ridge. Brand and/or keyword, please.
    Philadelphia, PA
    Honeywell FC40R1003. Should have your contractor verify airflow.
    Jun 2012
    Rockledge, Florida
    Quote Originally Posted by comfortdoc View Post
    I got two of the Honeywell 20x20x4 filters yesterday and put them in. They fit right in the existing filter returns with no fuss. I was able to reduce my fan speed to Medium and it STILL feels like there's more air coming out of the registers than with the old 1" filters and High fan speed.
    Even when the 1" filters were new, they slapped in a little too hard for my liking. Now, there's just enough of a pull to set them in place. I'm sure the SEER of my old Carrier system just got bumped up a full point. In short, upgrading to the 4" deep Honeywell filters are worth the price.
    Mar 2009
    Mount Holly, NC
    yup.
    now if i could only convince all my customers of this fact.
    it's amazing how restrictive the 1" filtrete filters are.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    SW Wisconsin
    Quote Originally Posted by btuhack View Post
    Additionally, make sure there is plenty of depth-room in the filter box so it doesn't end-up having an airflow restriction problem...
    Jun 2012
    Rockledge, Florida
    Quote Originally Posted by udarrell View Post
    Fortunately, the original A/C installer built an oversized framed-in box to set the air handler on top of. Large enough to hold two 20x20 intake grills with room to spare.
    Jun 2001
    Did the same thing on my ceiling returns. Rebuilt the filter grilles to accommodate the 20x20x4 filters. Excellent results, I left my fan on high speed. Unless you have humidity issues or have verified airflow, high fan speed typically is the best setting. Most ductwork is undersized and needs all the help it can get. Energy savings from reducing fan speed is minimal according to my kill-a-watt meter. 500W on high, 380W on low for my 1/3HP blower.
    Jun 2012
    Rockledge, Florida
    Fortunately, my air handler has a three speed fan. I'm sure Medium speed is somewhere between 500W and 380W.
    Yep, the humidity is suffocating where I am, on the east coast in Florida. I'd run the air handler fan on Low speed if I thought it could keep the house cool AND remove even more of this awful humidity!
    Jun 2001
    My furnace has a 4 speed fan, I just wanted to illustrate how little difference there is in power consumption between the lowest and highest speeds. Airflow changes considerably, power consumption not so much. You will loose more in condenser efficiency that you gain in blower savings.
    PSC motors take a big hit on efficiency when operated at part load. Variable speed blowers really save energy on lower speeds, some use less than 100W on low.
    Jun 2012
    Rockledge, Florida
    Quote Originally Posted by 54regcab View Post
    O.K., I'm getting a new education here. Even my old Carrier heat pump will be more efficient if the air handler fan is on high speed? The humidity in my house dropped only 3% since making the changes yesterday i.e. the new 4" filters and slower fan speed. Of course, I haven't received my electric bill yet to see if there's any difference.
    So, all else being equal, the air handler speed should be on High to get the best cooling for the money? Seems counterintuitive but, I'll take your word on it.
