Results 1 to 2 of 2
    Our Bryant HVAC unit is leaking water around the drain pipe on the part of the unit that is in our garage (not the compressor outside). The pipe isn't cracked or anything. It is almost like the the drain pipe is clogged?
    What could be the problem? Should we call someone?
    Southern CT
    If the drain and pan have not been cleaned this year, then yes, call someone in who is qualified to service the equipment.
