Page 1 of 4 1234 LastLast
Results 1 to 13 of 46
    Aug 2010
    Charge: r134a 0.90oz. how?
    http://www.crystalcoolers.com/Europe...ducts_E2O.aspx
    How would you charge something like this with such a critical charge?
    If there was a component changed, do you have to compensate for the difference in size?
    florida
    Quote Originally Posted by ICanHas View Post
    Weigh the charge in remember to compensate 2oz for your hose. And yes
    Educational forums are open.
    May 2009
    Earth
    Put the entire machine on the scale, since it is 134A you can charge it vapor.
    Quote Originally Posted by EugeneTheJeep View Post
    That's probably the best idea I've heard, yet.
    Feb 2012
    Toronto Canada
    Make sure you know how much refer is in the hose you got. Those ultra low machines need to be charged 100% right or it won't work right.
    Apr 2012
    Paper Street Soap Company
    Electronic scale. Convert it to grams.
    .90 ounces is 25.52 grams. Dont most digital scales have grams ?
    Jul 2000
    Cuenca EC
    I think if I needed a highly accurate way of metering out 0.9 oz of R134A, most digital scales wouldn't cut it because their accuracy and resolution simply isn't tight enough. A good scale with .1 oz resolution might get you between .8 - 1.0 oz, but is that good enough?
    A small charging cylinder might work:
    http://www.hvacr-tools.com/product/t...r-16-oz-r-134a
    But then, what about charging by the change in the pressure of the vapor in a cylinder? If the internal volume of the cylinder is known, vapor density info from a refrigerant properties table or program along with some simple calculations should work quite well. Remember we calculated how much vapor is left in an "empty" cylinder? I'm guessing this may as simple as taking a recovery tank with vapor at say 70 psig and metering out to maybe 45 psig. I haven't done the numbers, but that's my thought.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Jul 2000
    Cuenca EC
    The amount of R134A liquid in a 1/4" x 6 ft hose is .33 oz/ft or about 2 oz, but the weight of vapor is about 1/75 times that, or around .027 oz.
    florida
    Quote Originally Posted by icemeister View Post
    Who in there right mined charges anything with vapor.
    May 2009
    Earth
    Come on guys, you could just charge it the old fashioned way, amps, suction line super heat and pressures, all approximate of course. I would have already been done with this job, got paid, and it would have never been a thread here.
    Virginia
    Quote Originally Posted by crackertech View Post
    [/COLOR]
    oh hell thats easy dude ... just keep givin it squirts until shes beer can cold , and then race outta there like a heard of turtles , cuz shes good to go !
    [/COLOR]
    Small units, I do.
    It doesn't take long and allows me to charge more accurately.
    Everything else gets liquid charged
    Quote Originally Posted by Snapperhead View Post
    Im pretty sure Cracker forgot more about med and low temp than most, im just here to watch.
