Page 4 of 4 FirstFirst 1234
Results 40 to 49 of 49
  1. #40
    Kansas
    Fan motor maybe going out and not turning the rpms its supposed to be turning and took out the cap but still hasnt died yet.
  2. #41
    Jun 2012
    Pittsburgh PA
    possible ive either seen them good or bad I was thinking maybe the blade got bent but it dosent seem to be??
  3. #42
    Jan 2012
    WEST COLUMBIA S.C.
    What is temp difference of condenser coil air
  4. #43
    Jun 2012
    Pittsburgh PA
    26 degree but also air seems to be coming out the top 5inches of the condenser coils and out the top
  5. #44
    Jan 2012
    WEST COLUMBIA S.C.
    Has the fan blades slid down the shaft.Should be able to see mark from set screw on shaft if this has happened. I am saying this maybe a possibility since u are having air coming out 5 inches and homeowners have been around it
  6. #45
    Apr 2012
    Louisiana
    Quote Originally Posted by Brad gall View Post
    that's bad
    I'd check fan blade position and I'm assuming shroud looks normal. You said you had the right rotation.
  7. #46
    Jan 2012
    WEST COLUMBIA S.C.
    Can u follow up
  8. #47
    Virginia
    is the blade on upside down ?
    make sure the outter edges are pointing up , like as if the blades were cupped to hold water
    As for the pressures hunting , are you sure the piston is correct size ??
    Its not backwards is it ...
  9. #48
    Jun 2012
    Pittsburgh PA
    Blade hasnt slide down the shaft and not running backwards.
    piston also correct
    Amana tech wants me to change the blade and motor because he said it should be drawing closer to 1 amp and its drawing .6
    Sorry for the delay getting back to everyone I really appreciate everyones help thanks
  10. #49
    Jan 2012
    WEST COLUMBIA S.C.
    Thanks .
