Results 27 to 39 of 49
07-08-2012, 01:16 PM #27
Not saying this is it, but I've had two units do similar things with the fan blades in the wrong position on motor shaft. 1/2 an inch or more too low (or high though both of mine were too low) can make a difference. Check airflow with a piece of paper, move it over all fin surfaces, it should stick against coil. Any idea if the motors been changed before? Definitely seems like your having a heat rejection problem.
07-08-2012, 01:21 PM #28
- Jun 2012
- Pittsburgh PA
- 57
never been replaced but im wondering if the homeowner bent the blade cleaning out the unit
07-08-2012, 01:26 PM #29
Anyone!!!!!
I wish I was there.
Sometimes it's hard to troubleshoot over the forum.
I'm sure someone will be here soon.
To straighten out both of us.
I can tell you this much.
If u are checking ur high side on condenser port
And it shows that high
Ur condenser is not doing its job.
The flash gas to ur liquid line is what's causing ur fluctuation.
Not enough condenser,
Not enough air flow,
Go ahead replace the blade
It needs to be replace anyway, since it's bent
It will make bearing on motor go out.
I'll step back and see what others say
07-08-2012, 01:26 PM #30
07-08-2012, 01:28 PM #31
07-08-2012, 03:20 PM #32
- Jun 2012
- Pittsburgh PA
- 57
should the amp draw be half of the rla on one leg I think the rla was 1.2 & .6 on one wire
07-08-2012, 04:34 PM #33
Ok I have a few questions..
How was the unit performing prior to this year? Cool the house ok? Make set point and shut off? Did you ask the Homeowner these questions?
Are the indoor and outdoor units a match? How old is this unit?
Also when you evacuated the system are you using a micron gauge?Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
07-08-2012, 04:45 PM #34
- Jun 2012
- Pittsburgh PA
- 57
ran fine 8 years, pumped down with micron guage. matched amana 2.5 ton
07-10-2012, 07:59 AM #35
07-10-2012, 12:55 PM #36
- Jun 2012
- Pittsburgh PA
- 57
going over when I get a motor an blade just i ncase. It seems the condenseris not rejecting the heat an the condeser is clean for the amp draw to be that low???
07-10-2012, 05:05 PM #37
Professional Member*
- Jan 2012
- WEST COLUMBIA S.C.
- 205
compressor may be getting to go.the cap u replaced single or dual
07-10-2012, 05:13 PM #38
- Jun 2012
- Pittsburgh PA
- 57
dual cap 35/5/440
07-10-2012, 05:24 PM #39
- Jun 2012
- Pittsburgh PA
- 57
35/5/440 dual cap
