Results 1 to 9 of 9
Thread: tonage
    How do I figure out tonnage on my unit?
    Feb 2005
    Kentucky
    You can usually tell by the model of the condenser. What is the model number.
    Model - CKL24-1F
    Serial - 0306424230
    Feb 2005
    Kentucky
    Going by the model number it is a 2 ton. For every 12 is a ton you have a 24 for 2ton.
    Florida (some where) way-south
    that unit model looks like a 2 ton
    doing one call at a time.
    I have about 66 supply and a 78 return. It seems when the
    day warms up to much I'm losing. My pressures was 82 Low
    and 275 high. My UEI meter on the suction line read 48
    degree temp. Does everything sound right? The discharge
    line doesn't feel warm by hand. I'm wandering if it's
    more of an air flow problem or humidity.
    Nov 2005
    You need to call a Pro. You may have refrigerant charge issues from your readings.
    The posts and comments made by me are in no way affiliated with any company or organization. They are simply my personal opinions.
    Feb 2005
    Kentucky
    A 12 degree temp drop is low. The 82 suction psi sounds high for 78 return temp. If the suction line is 48 degrees it is slugging the compressor. What was the outdoor temp when you checked the pressures. Something is not right, is the equipment a matched system. It probably needs to be looked at.
    it was 94 out side.
