Results 1 to 9 of 9
    Jul 2012
    Central Air feels cool at first
    My central air feels cool when I first enter the room but after 15 mins, it feels sticky and warmer. I'm sure my system is undersized because the previous owner added on to the house and left the 2 1/2 ton unit. Plus it's been close to 100 for many days in a row here in Indiana, so the unit never stops running.
    Would a floor model dehumidifier help this?
    Mar 2011
    Manchester NH
    Call a pro. A dehumidifier would probably help, but thats not going to solve the underlying problem.
    Southeastern Pa
    Op:
    Future posts from you belong in AOP Residential.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2012
    Ohh.. This is one of Those forums... C-ya !!
    Dec 2008
    Buffalo NY
    Quote Originally Posted by BillinIndiana View Post
    Bye bye
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Mount Airy, MD
    Thread is relocated to the AOP should you return and wish to ask further questions......
    Southeastern Pa
    As an old church lady once said about her no-good son in law...
    "Don't let the door hit ya where the good lord split ya."
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Now, let's look at this objectively.
    Your design temp is probably around 95, so the unit should run constantly under those conditions.
    The symptoms that you describe don't really match your diagnosis.
    An undersized unit tends to run a lot and remove more humidity than an oversized one, so being warm and sticky aren't exactly a match for an undersized system.
    I'd start with having the unit professionally serviced by a reputabe contractor to verify that the unit is working as well as it can.
    If, after that, the unit doesn't provide the comfort that you want, start by sealing the envelope of your home. Insulation, weather sealing and the like can go a long way to increasing your comfort AND decreasing your electric bills.
    SW Wisconsin
    Check All the causative Factors 'before' you Condemn Unit as being too small
    You always have to examine all the the factors that can cause the comfort problem you describe; however, it well may NOT be an undersized 2.5-Ton system.
    There are many things that can cause the sticky too much humidity situation.
    Well, near 100-F outdoor air can hold a lot of moisture grains of moisture, therefore a blower door test might be in order. In fact try to find a way to get a complete Home Energy Efficiency Audit.
    The duct system needs to be checked for proper sizing & Return air leaks from that hot attic or garage area.
    I could make a 'long list of things' that can cause the humidity to be too high in your home at any temp between 70 to 80-F.
    However, I have to type with the eraser ends of pencils, so will let other PROs list all those factors concerning the HVAC System & the home... a smaller system that runs super efficient with the longer cycle runtimes required for dehumidification, is what is needed.
