Results 1 to 13 of 25
Thread: 460 volt 3 ph
05-30-2012, 07:39 PM #1
- Dec 2008
- 7
460 volt 3 ph
Found 6 units at one store all with the disconnect mounted on the door and the wires with nothing but black tape to protect them. If the tech that did this sees this post I added the picture of the correct location after I moved all of the disconnects so no one would get killed.
05-31-2012, 12:53 PM #2
New Guest
- Dec 2009
- 5
Thats one way to keep the copper thiefs away.
05-31-2012, 04:08 PM #3
Some things never change.........sigh......
06-01-2012, 12:27 AM #4
- Nov 2009
- wasilla, alaska
- 21
3M 33+ ?
06-02-2012, 03:59 PM #5
06-03-2012, 08:01 PM #6
- Feb 2007
- Central NJ
- 366
the reason i touch every unit i walk up to with the back of my hand before i proceed to do any work on it!
You have to pay your due's before you pay the rent!
06-03-2012, 08:10 PM #7
06-03-2012, 08:30 PM #8
Professional Member*
- Jun 2011
- New Braunfels, TX
- 47
06-03-2012, 08:38 PM #9
What i don't get is why the factory disconnect wasn't used on that unit. Not that it's a big deal but it sure would make more sense
06-03-2012, 09:31 PM #10
Personally I think it should be against code to mount discounts or DDC directly to any unit. Just simply cause they always seem to be right in my way.
If you're too "open" minded, your brains will fall out.
Artificial intelligence is no match for natural stupidity.
06-04-2012, 11:34 AM #11
Does anyone know how many laps of black tape it takes to keep back 600 volts?............................................ .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..................................ONE
06-04-2012, 01:49 PM #12
- Dec 2008
- 7
06-04-2012, 08:13 PM #13
- Jan 2005
- texas
- 110
