Results 1 to 7 of 7
    May 2005
    greensboro nc
    i remember that a start capactor is not real exact but run capactors are suppost to be the same,my unit has a run capactor dual 46/6 370v body is round.....i have a 45/5 440v. would that cause a problem or should i get one exactly?i know the higher volts would be fine.....the one that's in the unit is orginal and hasn't went bad but with the hot weather i want the correct one for a spare...this is a 3 ton heatpump with a scroll compressor
    Feb 2005
    Kentucky
    46/6 sounds odd, it would probably run ok on the 45/5 in a pinch. But I would maybe try to get the orginal from the dealer.What brand unit is that.
    May 2005
    greensboro nc
    goodman,cplt36-1......s.n.038409403 thanks for your reply
    Lancaster,Ohio
    Talking
    That does sound odd 46/6 is there a +/- 5% or 10 %? Where is the turtle when you need him?
    IcyFlame
    Feb 2005
    Kentucky
    You would have your 10% on the compressor but not the condensor motor.
    May 2005
    greensboro nc
    from the info i wrote down before it[old one] has a #27L568 on it and # b9457-72001/green...all i know to tell you
    May 2005
    greensboro nc
    called johnston today,they said 45/5 was fine.....still wonder why 46/6 was oem....is their a formula to figure what size capactor is used....the condensor side is what bother's me
