Results 1 to 11 of 11
    Houston, TX, USA
    Question Condensate pump for 7.5 ton
    Has anyone used a condensate pump for a commercial split system? Unit is 7.5 tons and there is no where to run PVC drain lines. Only solution is to go to roof 20' high.
    Nov 2005
    I have used pumps plenty of times, but a 20' lift is going to be expensive. I would see if I could tie it into a sink drain in a janitors closet. You may have to check you local codes.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Houston, TX, USA
    No sink or janitors closet nearby. Only option is pump up to roof.
    Jul 2011
    East coast USA
    Quote Originally Posted by caddy View Post
    Than you have to find a place. 20ft head is rough and not a good idea. i can envision the problems.
    Houston, TX, USA
    There is no place nearby and unit is installed in center of warehouse. There is no sewer or drain in building due to its just a parts storage. GC wants to pump condensate up to roof.
    Jun 2006
    New Jersey
    Look at the Hartnell A5X series. Lieberts use them and I know the have some major flow and lift.
    Jul 2011
    East coast USA
    http://www.grainger.com/Grainger/LIT...&cm_vc=IDPRRZ1
    add check
    Tujunga,CA
    http://www.diversitech.com/Product-L...0000005QEykIAG
    saw this at the supply house the other day,dont know if it will work
    for your application.
    IL
    Quote Originally Posted by evil_ss View Post
    Stay away from! JUNK! Had 3 of those fail in the last month all brand new pumps... 2 of them motors were junk and other one pump would only push water like 3 feet high.
    Apr 2012
    new york
    Liberty Model 405
    1/2 hp Commercial Drain Pump
    I use it for washer machines slop sinks etc only problem it needs to be vented you can run the vent up to the roof with the drain or considering its not connected to a sewer you could get away with going out the side wall of the building it has plenty of head for what u need
    Jul 2012
    Southwest
    20' isnt that high, you could run copper and it would work fine.
