Results 1 to 12 of 12
Thread: York ycav
    Jun 2010
    northwest connecticut
    York ycav
    Getting a low dc bus pre- charge voltage. I have read some of the troubleshooting for this drive and it appears it could be a problem with the scr's not firing or a shorted capacitor. Anyone with any first hand experience with this paticular issue I would love to hear from you ,Thank you!!
    Somewhere in the world.
    It's very possible something is shorted but I can tell you that the YCAV doesn't have any SCR's it is a VFD drive very complex piece of equipment lots of things that could go wrong and you could hurt yourself or someone else if you don't understand the principles behind the technology.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Jun 2010
    scr diode modules as part of their "drive" yes they do, just looking for a little input from someone who has more experience than me on this paticular machine, or maybe actually run across this very same issue !!! I am not a diy guy been in the service buisness for 30 years.
    Sep 2011
    Northwest Louisiana
    Do you have service manual on drive?
    A LITTLE BIT OF STUPID GOES A LONG WAY!
    Jun 2010
    No, i do not have a manual for the drive itself!!!
    Quote Originally Posted by hvac1966 View Post
    They are structurally different and operate differently. In an SCR, operating off of a direct current source, once turned on by a control signal the device will stay on if the control signal is removed. With an IGBT the device turns off when the control signal is removed. Just thought I would send you this so you can see the difference between the two.
    Sep 2011
    Northwest Louisiana
    Post email address
    Jun 2010
    Sep 2011
    Northwest Louisiana
    I am at the airport picking up oil pump for important customer, when I get home I'll send you an email.
    Jun 2010
    Thanks !!!!
    Indiana
    I had this problem two weeks ago. Luckily I had two chillers with one of them runable. Had to result to part swapping for two of the boards. My problem ended up being the SCR trigger board which is pretty expensive. Replaced it and it's running great.
    Jun 2010
    Thank you very much , I apppreciate you sharing this info it makes the troubleshooting process alot easier !!!!!!
