Results 40 to 52 of 58
07-05-2012, 10:53 PM #40
07-05-2012, 10:54 PM #41
- Jun 2012
- Wisconsin
- 38
Thanks JP, is that formula and chart for charging any cooler or freezer?
07-05-2012, 10:56 PM #42
Print 90-30-1, laminate that SOB and store it in your clipboard.
Or, move into the modern age and download it to your smartphone and keep it in your pocket.
Very handy chart to have.
07-05-2012, 10:57 PM #43
07-05-2012, 10:59 PM #44
07-05-2012, 11:00 PM #45
- Jun 2012
- Wisconsin
- 38
Thats what I thought. What would be an appropriate way to charge a walk in cooler or freezer with just a txv? Where on sporlan's website should I try to find this information?
07-05-2012, 11:04 PM #46
07-05-2012, 11:04 PM #47
07-05-2012, 11:07 PM #48
- Jun 2012
- Wisconsin
- 38
Maybe ive just got a bad case of the stupids from working in the heat all day, but the sporlan 90-30-1 link was for charging a system with a headmaster.
Shouldnt there be a different chart for charging just a simple condensing unit without a headmaster?
07-05-2012, 11:09 PM #49
07-05-2012, 11:11 PM #50
- Jun 2012
- Wisconsin
- 38
If im staring at a sight glass by the condensing unit and the box is lets say, 30 feet down the way and 20 feet vertical. How is it that clearing the glass 50 feet away ensures a solid column of liquid to the metering device?
07-05-2012, 11:35 PM #51
07-06-2012, 12:50 AM #52
- Jun 2012
- 37
This is a common installation manual that I find with all the condensing units I install. Has lots of good info such as line set sizing, flooded condenser charging, and lots of other good stuff. Of course you can't use the charging chart for other units because that depends on what size receiver they have on the system, but if your btu's are close to the units on this chart I bet it will get you pretty close. And I use the line set sizing chart for just about all walk-ins I install.
http://69.41.183.10/documents/Russell_SYS_IOM_550_1.pdf
