Results 14 to 26 of 58
    Quote Originally Posted by CommtechinVA View Post
    One guy said subcooling on walk in refrigerator should be 8 degrees.
    A tech asked him and then asked me. I told him it wasn't all that important because you have a receiver. He was bothered by the fact that he got two different answers from the field supervisors. I told him to clear the sightglass and be sure to have some subcooling. As for superheat, I told him 20 degrees at the compressor. I know this can vary but it seems to be a good starting point. This situation is what prompted me to ask you guys what your thoughts are.
    Don't forget that you may need to add flooding charge for low ambient conditions if you have condenser flooding valves.
    Mar 2009
    Mid-Mo
    Once you install a receiver on the system, you're still worried about a solid column of liquid, but the way that you ensure it changes from subcooling measurement to a sightglass.
    So, I guess to answer your questions, subcooling "is what it is" and superheat should to be as low as it can safely run without damaging the compressor.
    X2
    I've been setting ours to 6-10 degrees at the outlet of each evaporator.
    Of course the compressor manufacturers are going to say 20 degrees SSH, they are going to make sure they don't get anything back to the pump. A lot of he larger screws I have worked on run as low as 2-4 SSH.
    Oct 2007
    Richmond, VA
    I need to research more on flooding valve systems. I haven't ever Dealt with one.
    Apr 2011
    michigan
    I have used these settings for my refrigeration units and have had no problems with these superheat and subcooling values for a starting point, usually they work just fine and dont need much adjusting from there in my experience.
    Jul 2000
    Treasure Coast/Florida
    Sporlan's Bulletin 90-30-1 is a very good source of info with regards to charging with a flooded head pressure control:
    http://sporlanonline.com/90-30-1.pdf
    The procedure look rather daunting at first, but after you've done it a couple of times it's fairly straightforward.
    Apr 2012
    Paper Street Soap Company
    Liebert uses headmasters on their smaller units for low ambient operatjon.
    If not for those units I would have had zero exposure to flooded condensors.
    They are nice enough to put a sight glass on their recievers to make adding its winter charge a snap.
    Quote Originally Posted by icemeister
    What he said.
    Quote Originally Posted by Toddbrewster
    The point is, there is a right way and a wrong way to do things.
    Your method is not the correct way to charge MOST refrigeration units.
    Read the PDF that icemeister posted. You'll learn something.
    Mar 2012
    Omaha NE
    There is much to learn here. So I am commenting to be able to find this information for later use !
    Jun 2012
    Wisconsin
    The only thing I noticed wrong, maybe I need to be educated, is that for a blend refrigerant you cant charge as gas and you would add charge prior to intial start up on high side. Let system equalize, start unit and then bleed liquid into the low side.
    Jun 2012
    Wisconsin
    If superheat and subcooling dont nescessarily matter in refrigeration, how am I positive I have a solid liquid column to the txv?
    Mar 2009
    Mid-Mo
    Quote Originally Posted by Bseliger View Post
    His point was on a system with a receiver subcooling is essentially not necessary to check. You ensure you have a solid column of liquid by looking at the sight glass and clear the gas. Add the appropriate additional charge for condenser flooding if it had a headmaster valve.
    Superheat values are important but are different than your standard a/c applications, generally speaking.
    With a sightglass...
