Thread: finding the size of a ac unit
07-03-2012, 06:24 PM #1
New Guest
- Jul 2012
- St.Louis
- 3
A used ac unit was given to me and i know that I have to also replace the evap coil but I’m not sure what size the condenser is, I do have the model number and was hoping that I can get the size from it, the model is 533GNX024000AAA, I am thinking this may be 2.5 ton, if anyone knows please help, just so you know it is a R410a unit too. thanks!
07-03-2012, 06:27 PM #2
2 ton
07-03-2012, 06:30 PM #3
New Guest
- Jul 2012
- St.Louis
- 3
Thanks, now it would not hurt to get a 2.5 ton evap coild would it?
07-03-2012, 06:37 PM #4
Its usually fine but without all the numbers off of both pieces cant say for sure.
07-03-2012, 06:45 PM #5
New Guest
- Jul 2012
- St.Louis
- 3
so to be safe i should buy a 2 ton evap coil then? And if I do I will try to find the same brand, I think its a Carrier?
07-03-2012, 06:48 PM #6
You need to get with the supplier or a dealer so they can get you a correct match.
