Page 3 of 3 FirstFirst 123
Results 27 to 29 of 29
Thread: Walk in Freezer
  1. #27
    May 2010
    I would like to retract my statement about you having to have a contact or. If it is a small unit then there is no need for one.
  2. #28
    State College, PA
    Quote Originally Posted by ZeroTolerance View Post
    That would be a pretty small walk in.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://icemeister.net/aop_map.html
  3. #29
    Oct 2009
    Knowing the compressor can pump to around 0, try to set the low pressure control by using a small handy air pump ( most supply have it) , along with a good continuity tester and accurate set of gages, your cut out should be 0 psi, then rewired the pressure control so when it opens the condensing unit will shot down
