    Aug 2011
    Tridium Irrigation control
    I am looking for a solution to integrate a large irrigation system into a Tridium Web Station AX front end. I have looked at Atkinson but they do not support the Ax version of Tridium at this time. I have 8 Control towers with 12 zones each. I have figured out hoe to convert the sprinkler system form hydraulic to electric. The integration into the Tridium is the issue i have.
    Mount Airy, MD
    Quote Originally Posted by Arctic2008 View Post
    Way more info needed here to answer this properly
    Can do "anything" your little heart desires without issue.....
    Cedar Rapids, IA
    By hydraulic I assume you mean the rotating valve that selects the next zone everytime the water is shut off and back on again. You would not have to replace that. A custom control routine could be written to deal with it. How is it currently controlled? What turns on and off the water to the 8 control towers?
    You may have to adapt this controller's protocol (Modbus/TCP, SNMP, HTTP). It's from ControlByWeb. 10-high current outputs onboard.
    http://www.controlbyweb.com/webrelay-10/
    Aug 2011
    existing mechanical controllers are broke. I cannot get parts to repair them either. and yes there is a rotating valve. The person mowing the lawn is currently turning the controllers on and off by hand.
    Cedar Rapids, IA
    If the rotating valves are still operable, then you would need a 24volt solenoid valve for each station. Then control of those solenoid valves would require 8 digital outputs from a controller on that is connected to the ax. (Assuming 8 rotating valves). It might be nice to put a pressure switch on one branch from each rotating valve to confirm that it has completed a cycle. That would require 8 inputs.
    You could also install a valve for each zone and eliminate the rotating valves, but you would need more outputs/controllers and water solenoid valves as well.
