Results 14 to 26 of 41
    Jan 2012
    Fraser Valley
    Quote Originally Posted by matt1124 View Post
    Electromagnetic and inductance theory is not for the faint of heart. Unless you want your brain to explode just learn the basics for the trade. Capacitors resist a change in voltage, inductors resist a change in current.
    Luckily someone much smarter has figured out that motor made of a number of coils wrapped in a certain diameter circle pushing a piece of steel made of more coils of wire needs a 7uF capacitor.
    I hear you loud and clear brother- but having more than the basic understanding is what I believe is one of the components that helps to create the difference between a guy who knows what the right part is and WHY the right part is what it is.
    May 2011
    Oklahoma
    Quote Originally Posted by WestcoastApprentice View Post
    I believe that too. If you know the process behind something you can do any job better than just throwing parts at it. I graduated from OK state an EE but i don't think knowing why that motor needs a 7uF and not a 5uF make be a better motor diagnostician. Good luck in your studies!
    Dec 2003
    Nevada
    Quote Originally Posted by timebuilder View Post
    Yep.
    He needs two things:
    1) The Dale course, (http://www.westegg.com/unmaintained/carnegie/dcc.html)
    and
    2) the Forrest Mims book.
    http://www.amazon.com/Getting-Starte.../dp/0945053282
    The Dale Carnegie book How to Win Friends and Influence People has the potential to change your life. I would venture to say that it will make you more successful in HVAC/R than knowing how the magnetic lines of flux in a motor winding affect something you'll rarely ever measure anyway.
    That is not to say that you should not seek out an answer to your question. Just realize one is wisdom the other is knowledge.
    Good luck.
    Quote
    “Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
    "We can't solve problems by using the same kind of thinking we used when we created them."
    Albert Einstein
    Jun 2012
    It goes so much more in depth than that though. A lot of electrical engineers (I didn't say all) would not be able to remember the physics behind all of this unless they use it every single day. I know I had a better understanding of it a few years ago. Use it or lose it...
    Apr 2012
    Paper Street Soap Company
    honestly guys- No offense intended whatsoever and if coming across as arrogant or as having what we refer to here in BC as "the refrigeration walk" then I most sincerely and humbly apologize to all.
    As timebuilder said, I should have been more specific and said the RIGHT HVAC company. I've had several peers from other companies as well as mentors who have spent their careers in HVAC and have a very impressive understanding and well rounded perspective to many things not found in the more 'purely-refrigerative' areas of the trade (for lack of a better term).
    Apologies to all and many thanks for the great links as well
    Although it's important to have a thorough understanding of the principles of electricity and how individual components effect the operation and power quality of a circuit it's not knowledge that you're going to be using in the field as a tech.
    I use to be into electronic hobby building and avionics so the study of components in both AC and DC circuits actually interest me to a great deal.
    In response to your first post the effects of capacitance and inductance on a AC circuit as far as you should be concerned relate to over all power quality.
    Power quality can be expressed as that circuits power factor which is a ratio of real power to apparent power. It's a measure of the efficiency of the power in a circuit and is expressed on a scale of 0 to 1.
    Real power is the power that actually performs work and apparent power is the effect of resistance, inductance and reactance in the circuit.
    Both capacitors and inductors store energy. Capacitors store it in their electric field and inductors store it in their magnetic field. The combinations of these two elements in a circuit with resistance add up to that circuits total reactance. Also note that capacitance and inductance change with frequency.
    Since frequency is constant ( 60 hz ) it's not an issue in typical linear power distribution.
    So in purely resistive linear circuit the current and voltage waveforms are in synch and your power factor is very close to 1.0
    It's at it's most efficient. Once you start adding inductance, ( motors, relays, lamp ballast, etc ) and capacitance ( DC power supplies in computers and servers, and wire and cable have some capacitance ) you start lowering the power factor and that circuits efficiency and start adjusting the phase angle of current to voltage ( Voltage will Lead Current ) which will increase overall power consumption.
    Most buildings and especially industrial sites have a large inductive loads. ( big motors) and may require the addition of capacitor banks to correct the low power factor or pay a penalty to the utility company.
    You might see a capacitve bank sitting next to a pump motor or next to a service panel that feeds a number of electric motors. They're trying to increase their power factor.
    Capacitors and inductors in DC circuits have a variety of uses and unless your planning on getting into component level trouble shooting on circuit boards you don't need to waste time studying their many applications.
    Jan 2012
    Fraser Valley
    Quote Originally Posted by Six View Post
    If I was to continue in my career with only troubleshooting units of say 10 tons or smaller and basically be able to say "yup, change the board" or "yup, add a hard start kit" then for sure I would agree with your summarization of the importance of this type of stuff.
    The fault I have made in my apprenticeship thus far, and what I am trying to correct, is by listening to those who have said "just get a general understanding because you won't need to know that in the field".
    This perspective towards understanding only a portion of what I have been taught in school has been literally CRIPPLING when it comes to being able to apply a skill-set and knowledge-base from one type of equipment onto something different.
    The best technicians I have known and still know, and ALL of the mentors and live resources I turn to have extensive knowledge of not only electrical theory but also of refrigeration theory and refrigerant properties- characteristics that are FAR from common amongst most techs I have met here in B.C.
    The limited exposure I have had to larger scale refrigeration equipment tells me that when the day comes that I get called out to a plate style cooler system for a dairy tank with 50K of milk in it or to a 70 ton chiller system for a 40 story tower, I sure as HELL be a lot better on my theory than what would consist of a general understanding.
    I know that I probably come across to MANY as a young cocky know it all little $#!T but please believe me when I say that with every piece of knowledge I learn, read, see, or am taught comes with about 10 pieces that I feel anxious about until I learn (and no, I don't need to do the math on that equation to realize it's impossibility- LOL)
    But enough ranting for now- I'm probably overdue for a good punch in the teeth right about now anyways!
    Apr 2012
    Your post is a good example of how experience or lack of affects our perceptions of what's important and practical.
    The example you used of voltage and current waveforms leading or lagging was explained ( did you read my entire post? ) in context to our industry. If you want to pursue their characteristics as applied to DC theory GO BACK to school. Or rather enroll in a school that focus' on electronics. ( hope your smart because it's an entirely different animal than simple AC power distribution.)
    I've been in the industry for almost twenty years and have worked on everything from large kilo-ton centrifugal chillers to small 5 ton package units.
    My knowledge of electrical theory as applied to our industry and electronics is pretty extensive. Do I know everything ? No, I do possess some humility.
    That said I have yet to pull out my pocket note book and work through the electrical mathematic principles of a 100 ton air cooled chiller for purposes of trouble shooting.
    Understand the engineering aspect of the machine and the sight where it's located where worked out by people most likely more knowledgeable than yourself far before you arrived.
    As a tech I'm under obvious time constraints and it's my responsibility to quickly narrow down the offending component or issue causing the issue and repair it using correct service techniques without cutting corners and get to my next service call.
    If it's going to take a day or two to order in parts then let the customer know and then hit the road.
    What's important is understanding the specific functions of the specific type of equipment you're working on. Also a thorough understanding of the components and principles of refrigeration in general.
    IF you walk up on a 70 ton chiller that's off on high pressure do you need to know how to figure for total inductance ( XL = 2πfL ) ? Are you going to be wasting time connecting a oscilloscope and watching sinusoidal waveforms shoot across a screen ? No you need to be focused on the problem at hand.
    Nothing wrong with having a good base of education but because of your experience level you don't know what information is going to be useful to you.
    When guys who have been in the field for 20 years tell you what you need to focus on why would you question that ?
    Jan 2012
    Fraser Valley
    Hey very well said six, and I humbly salute thrice you, your comment, and foremost your expertise. My problem, however, has been learning where to draw the line and understanding what exactly falls under the umbrella of 'necessary knowledge'. I can't even begin to tell you how many examples I've had where I have been going in depth even a LITTLE bit on a call and had some instructor or previous journeyman's vioce in the back of my head haunting me with words of, "aawww $#!T- don't spend too much time on that, you'll NEVER need it in the field". Case in point: Psychometrics and enthalpy charts. I'll bet you that a total of 3 techs I have ever come across have said they've used them outside of the classroom. On a site like this, that I truly believe has some of the brightest minds from our industry, I think the percentage of guys who use them regularly would be a tad different. Hence why long ago I went back to my notes from school and hammered them into my brain a little bit harder.
    And so the question again then is dually: IS it just the school of hard knocks and you learn what you need to as you go? Or can someone like yourself give a good general recommendation of what kind of material a guy like myself can bury his nose in to raise above the general 'cliff notes' that 8 weeks of school a year gives you, without getting too carried away in the world of electronics theory?
    and p.s: re: your answer to the original question, I DO genuinely apologize for not thanking you for your response previously.
    Apr 2012
    . I think my self and mybe a few techs that specialize in different aspects of our industry could give you a good understanding of what knowledge is necessary.
    But that advice doesn't mean you have to stop learning and judging by your previous post it doesnt sound like you're going to.
    So I commend you for having a thirst of knowledge and dont ever let someone talk you into lowering your standards on what youre interested in or what you feel is relevant.
    Stay humble. Keep learning. and asking questions. Your value as a technician will be based on things like dependabillity, effectivness and eventually experience.
    Maintain a high set of standards and a strong work ethic. The knowledge will come with experience.
    Jun 2012
    I encourage learning. Having said that your view is similar to saying that a blacksmith needs to be a metallurgist to be a truly great tradesman. A thorough understanding of it has no bearing on their artistry really. I highly doubt you will have an oscilloscope next to vac pump on the truck at all times. To know what causes problems doesn't require a lot of physics. You stick your clamp on ammeter on a motor wire and see a higher than normal amp draw. A solid basic knowledge of electricity will allow you to find the issue, just rule mechanical issues in this case. A clamp on ammeter is a fantastic example of useful inductance by the way. Keep us posted on your progresses too. You're ambitious and it shows.
    Jan 2012
    Fraser Valley
    Thanks a lot guys. excellent feedback once again
    Feb 2007
    Central NJ
    Quote Originally Posted by Dallas Duster View Post
    Occupation
    Refrigeration mechanic Apprentice, recently left HVAC to be a real refrigeration mechanic
    Yep he's just a know it all kid.
    just what we need in the trade: another know-it-all who constantly flaunts it and believes he's on a higher plain of existence because he got a knew job. would love to tell him good luck but would rather hear about him crashing and burning so it can humble him up a bit......... or break him
    You have to pay your due's before you pay the rent!
    Southeastern Pa
    Perhaps the most effective method of assimilation is what I call "learning in context." If you spend time with the Forest Mimms book I showed you, and do some basic work in it, you will achieve the basic background needed to have a synergy of knowledge happen in the context of your working days. This is APPLIED knowledge, and it's the best kind.
    Forest won't get you "too carried away," although he is one of the foremost experts in the field.
    Any "first semester" course in electronics will give you all the basics you need, and that is Forest's approach.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
