Results 14 to 26 of 52
    Virginia
    you didnt install it backwards didya ...
    Apr 2012
    Paper Street Soap Company
    I would be concerned to if a new install is running with zero superheat.
    Liquid refrigerant is most likely making it back to the compressor. If its not causing damage by way of slugging its washing the oil and eventually you'll experience bearing failure.
    Its hard to believe you have any liquid seal with a Txv wide open. If you've confirmed your readings are correct and there is no adjsutment on that TXV then your only option is to replace it.
    Jun 2012
    Pittsburgh PA
    Thanks alot for all the help.... 12 degree subcooling and 0 on the superheat both measured at the condenser. everything else seems fine and its cooling well, I should have disconnected the bulb rather than relying on the heat sink though. If anyone thinks of anything else to check id rather not have to change out the valve. thanks again
    Jun 2012
    Pittsburgh PA
    The txv was factory installed and insulated I did use heat sink around the connection, maybe not enough
    Jun 2012
    Pittsburgh PA
    Thanks SIX I thought overheating the bulb would close off the txv??
    Houston,Tx.
    Quote Originally Posted by Brad gall View Post
    .12 degree subcooling and 0 on the superheat both measured at the condenser..
    This just don't make sense to me, you would think with only a 12° SC if you were able to get that with a wide open valve, that there would be some flashing, and not have a 0 SH, heck you got me. That coil come with a piston and you forgot to remove it?
    Jun 2012
    Pittsburgh PA
    I just checked my notes on the job the unit is requiring 12 degrees of subcooling and i had 10. Could it be slightly overcharged?
    Houston,Tx.
    Well if it calls for 12° and you have 10° it could be, but I find it hard to believe it's going to make a lot of difference in the SH if you have 0 SH. You can try, but you really don't know where you are with a 0 SH, bring the SC to 12° and see if you get any SH, only way to find out.
    Philadelphia, PA
    Operating pressures and temperatures. The SC indicates undercharge.
    SP
    LP
    ST
    LT
    IWB
    IDB
    ODB
    If you provide data we can help.
    Jun 2012
    Pittsburgh PA
    sp-143 50degree F at condenser (410a refrigerant)New install
    lp-381 115 degree F at condenser
    IWB -? dont have now
    IDB-70
    ODB-85 inlet condenser air/ 98 exiting condenser (93 in sun)
    R/A temp 70
    S/A temp 51
    Houston,Tx.
    Sure seems like a high suction and head for a 70° ID RA/DB.
    Jul 2005
    IDB-70
    R/A temp 70
    S/A temp 51
    If the 115 is liquid line temperature you have 2° SH on the liquid line.
    Jun 2012
    Pittsburgh PA
    Shouldnt my superheat still be higher even if its overcharged?
    Thanks alot
