Results 1 to 10 of 10
    Sep 2011
    2t Lennox with matching evap this morning.
    Started 9am left with system running at 12:30pm.
    2 Ton Lennox 13 SEER 410 condenser with a c33-24a-2f evap, no txv changeout from r-22.
    When done, I had 21f temp drop. 37f at first supply.
    Ambient at half past noon was 101f.
    I left the tstat at 72f and asked her to call me when if satisfied. She called at 3:45 saying it had reached 72f and temp right now in Atlanta area is 102. Im very happy with this install since I didnt encounter any hang ups.
    Flushed line set with rx-11, nitrogen press test and sweep. Vacuum 30 min, (without micron gauge... I know, I have to get one)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	273581   Click image for larger version.
ID:	273591   Click image for larger version.
ID:	273601   Click image for larger version.
ID:	273611   Click image for larger version.
ID:	273621   Click image for larger version.
ID:	273631   Click image for larger version.
ID:	273651   Click image for larger version.
ID:	273661   Click image for larger version.
    Sep 2011
    She didnt have enough money for the furnace so I'll change it later on in the year. One very happy customer whose tstat never saw the underside of 79f.
ID:	273691   Click image for larger version.
ID:	273701   Click image for larger version.
ID:	273711   Click image for larger version.
ID:	273721   Click image for larger version.
ID:	273731   Click image for larger version.
    Nice work. That old A coil looks older than the outdoor unit.
    But get a micron gauge!
    Phoenix,AZ
    What's up with the 7th pic? Did you find some Viagra?
    Jun 2011
    Houston area
    Quote Originally Posted by KB Cool View Post
    Those are the 1000 mg version. Why do you think he left at 12:30?
    BTW - nice work!
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Phoenix,AZ
    Quote Originally Posted by Cooked View Post
    Sep 2011
    lol.... Those are pan treatment tablets. I put two in in every evap install. I cant remember why i started doing that. It just feels right.
    Aug 2008
    San Clemente, CA
    Nice work. When you do the fau you should install a float switch on the overflow outlet of the coil. I would also route the condensate drain line with better clearance from the vent.
    Jan 2011
    Quote Originally Posted by gesellman View Post
    Them stupid things are expensive for what they are... I only use them on condensate pumps.
    Sep 2011
    Quote Originally Posted by JKopp View Post
    Thanks for the feedback. She declined the overflow switch and signed a waiver. She was at her limit with her cashflow or we would have gone for the furnace also at this time. The drain line is farther than it looks from the vent pipe, and that first piece of vent is double wall so its safe from the heat. Thanks for pointing those out anyways, both valid points.
