Results 1 to 13 of 23
    Nov 2007
    KANSAS
    large tonnage RTAA
    Is there a way to lock Compressor b out and run just A
    Keokuk, IA
    Model number would help. Is this a 2 compressor or 3 compressor unit? Are A&B on the same circuit or separate circuits?
    I thought in the menu there was an option to disable or take a circuit or single compressor out of service.
    We're running a 300T until with just compressor C, since circuit 1 has too many leaks in impossible to fix locations, so its' been abandoned. The building only actually need 100-120 Tons anyway.
    Nov 2007
    KANSAS
    Large tonnage AA yes a and b are twinned b and c it a single compressor I know you can lock out circuits but not compressors it is the old black box type controller
    Apr 2012
    Paper Street Soap Company
    Quote Originally Posted by Riverghost View Post
    Yes, in the service test menu.
    I will cycle through pumpdown cicuits, then EXV test and then lockout circuit A, B,.
    Apr 2012
    It will cycle through pumpdown cicuits, then EXV test and then lockout circuit A, B,
    Idividual compressors on a tandem (twinned ? ) configuration can be isolated by pulling the control wire.
    Is one bad ?
    Apr 2012
    If it's a burnout I wouldnt recomend running it.
    I dont like to isolate individual compressors on a tandem assembly after compressor failure.
    Large tonnage...
    that's vague. what is large to you? what is small?
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by jayguy View Post
    Large/small, fat/thin, short/tall, smart/stupid, ugly/pretty, normal/weird: all depends on who you're standing next to at the moment.
    Quote Originally Posted by klove View Post
    but what if you're 'pretty ugly' like me?
    Not in Iran
    Then we shoot ourselves ,
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Dec 2008
    Dixiana, AL
    That's a fair question concerning the idiosyncracies of the American English language. Not knowing you personally, I can't comment on how it actually applies in your case......
    Oct 2006
    Central Texas
    Well, you could always find somebody uglier to hang around.
    Sic Semper Tyrannis.
    Quote Originally Posted by txhvac View Post
    like ron jeremy? oh, wait. that won't ALWAYS work.
