Results 1 to 7 of 7
    Jun 2012
    Trane Model Numbers - Upgrading Townhome
    Hi everyone,
    I have a townhome, approximately 1500 square feet. My existing a/c unit is original from when the house was built in 1986.
    I've had a couple of companies over to give me estimates. I'm having some difficulty finding information on the equipment quoted in one.
    Quote:
    Trane 1.5 Ton XB Air Conditioner M# 4TTB4024 (15 SEER)
    1.5 Ton Evaporator Coil M# HG81636
    Can anyone identify which unit and coil this is? Google hasn't helped me at this point.
    Thanks for reading and any info you can provide!
    Mar 2006
    The South
    Slate
    That AC condenser appears to be XB14 model, a 2 ton not a 1 1/2 ton.
    Off hand, I don't recognize that evap coil mdl number as being a Trane and suspect it is a third party brand. I wouldn't have it.
    See link on XB14 AC condensers.
    How do you heat?
    IMO
    http://www.trane.com/Residential/Pro...r-Conditioners
    Virginia
    Call the contrctor and ask him if you can see the ahri rating on that match up
    Jun 2012
    Thanks for the quick replies.
    tigerdunes - The contractor told me that this model was a couple of years old, and that I would be getting a good deal on it. If it is actually an XB14 2 ton, and he mistook it for an XB15 1.5 ton, this makes me skeptical to go with this company.
    The sad thing is that they have numerous great reviews on a few sites.
    My home has a gas furnace, and is as old as the existing a/c unit. The contractor told me with the a/c and coil upgrade, future upgrade of the furnace shouldn't be a problem. I just can't afford to both at this point.
    catmanacman - I'll ask him about the AHRI rating. Thanks.
    The coil is an ADP. Rated at 15 SEER with the 4024.
    Jun 2012
    Thanks the info. I searched Google for reviews on ADP, and they seem to be a mid-grade semi-decent coil.
    Virginia
    I would want a trane all aluminum coil its my experiance that they are holding really well i would not want the adp coil
