Results 1 to 13 of 13
    Dec 2010
    Goodyear, AZ
    New Goodman, bad compressor
    Changing out a bad compressor today on a Goodman 410 split system. Low side running at around 150psi / 50 sat temp with about 8 superheated. High side 425psi/130 sat temp with 10 subcooling. Brand new system, pullin my hair out. Was messing with the txv , thinking the evap is flooded trying to get the sat temp/pressure lower. Finally tried to pump down system to check comp. pressure started to go down then " valves" gave out and pressure went back up. Bad compressor right? Not pulling the low side down enough?
    I have another client, same system having same problem. Anybody running into some bad goodmans?
    May 2005
    South
    Sounds like an overcharge and maybe something going on with the metering device.
    Thats based on the information you provided, keep in mind I'm not there and never have been.
    Sep 2011
    sounds like overcharge. I would recover what the compressor cant pump down, vacuum open valves and try one more time... Goodmans come precharged and they have enough to get system running right with about 15' of line set depending on the size. Good luck!
    Aug 2008
    Burlington , Mass
    Sounds like an overcharged unit. When it cant pump down fully, the safety valve in the compressor opens up. Recover some gas and start over. Then diagnose problems.
    I'll be there when I get there and not a minute later
    Virginia
    Have you checked your temp split
    May 2005
    South
    Does it have a micro channel coil?
    What do you mean buy messing with the TXV?
    Not enough info
    What ambient temp?
    IDWB.
    150 psi is normal on high indoor temp.
    Pump down not recommended on checking comp specially a scroll
    Dec 2011
    Twin Cities Minnesota
    Did a Goodman 13seer with no Hi or Low pressure switches yesterday.., start up over 600 psi hi side. Compressor never even rattled,recovered some 410,worked great!
    Not enough info, at the lease we need the outdoor temperature, and the dry bulb and wet bulb temperatures of the indoor air.
    Your pressures, SH and SC look pretty normal for an R-410a system on a 105Ί+ day with a moderate indoor load.
    If the refrigerant lines have much length to them, you won't be able to pump the system down without removing some refrigerant, especially with Goodmana units that have the "smart coil" condenser with the small tubing.
    Jun 2012
    Pittsburgh PA
    I was always told not to pump down the scrolls. I usually pump it down some and recover the rest
    Jul 2009
    South Carolina
    Every Goodman 410A unit I've put in has been overcharged.
    I just did a 4 ton system with an 85 ft. lineset & I didn't have to add an ounce of gas. I should have needed about 3 lbs. or so but all the numbers were perfect right out of the box. I'm starting to think that maybe their numbers that are stamped on the units are wrong. Even their dry 22 units seem to take less than what is stamped on the units.
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
    Apr 2010
    We've had many Goodman units come from the factory overcharged. And undercharged, for that matter. One unit in particular, I weighed out 27+lbs on a ~18lbs unit. Oh, Goodman.
    To the OP, what's the word?
    Aug 2009
    Peoria IL
    its that dam metric system pounds kilos oz grams
