Results 1 to 8 of 8
    Apr 2011
    South Central Tennessee
    Dual-Fuel HVAC Compressor Cooked
    I have a 15-yrear old America Standard dual-fuel heat pump. The service man just left, bad news, the extreme heat (104 degrees) apparently cooked the compressor. Don't know the cost for a new compressor, but I figure it'll be nearly $. My gut tells me that I'd be better off replacing the unit - especially being that old. I 'd appreciate your expert opinion/advise. Thanks.
    Pete (The Oldfella)
    NW AR
    At that age Id replace it.
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by ar_hvac_man View Post
    what he said.
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    Apr 2011
    Thanks, much appreciated.
    Pete
    Apr 2011
    There is a twist to this story. It appears the my system (compressor) will not respond at temperatures over 95, this is the third time I noticed this issue. After the temperature drops to 94/95, the compressor comes on - does this mean it is a somewhat normal issue, or should I pursue the replacement route.
    Since it does cool off for evening/night comfort, I am hoping this thing will continue to work, even if it's part time, until Fall? Again, thanks in advance for your advice.
    Pete
    Condenser coil may be too dirty and just need cleaned.
    Nov 2010
    N. Idaho
    I don't believe the"Extreme" heat killed your compressor. There's another issue.
    Lots of places consistently see those temps all summer! You're obviously not 100% convinced either or you wouldn't be here asking, I'd try and get a second opinion.
    "I've got my Gas Mechanics license"
    "Yea, well my 16yr old daughter has her drivers license, doesn't mean she knows how to drive"
    Virginia
    I would change service comanys first and get the real problem repaired if the compressor runs and cools at 94 degees doubtfull its bad
