Results 1 to 10 of 10
Thread: SEER Ratings
    Jan 2012
    Springfield,Il
    SEER Ratings
    How do you determin the SEER rating for condinsing temps over ambient?
    Mar 2012
    West Chester, PA
    huh?
    Houston,Tx.
    There is a member here named Twilly, this is his avatar I think he has the conversion book for $29.95.
    Jan 2012
    Springfield,Il
    ok they say condensing sat point is up to 30 degrees over ambient. but lower for the higher SEER rated condensors. how do you know what the seer rating is of the condensor your working on?
    Mar 2012
    West Chester, PA
    the nominal seer is indicated in the model number if you know how to read it. otherwise you would need to consult some other literature. the system seer is determined by the combination of equipment and can be found through the AHRI directory. To my knowledge there is no universal rule taht sais the temp diff between coil and outdoor air should be X for a given seer rating. I would think it would have to depend on the manufaturer.
    Jan 2012
    Springfield,Il
    O I recently graduated hvac program teacher said up to 30deg. then read a post on here guy said he used this
    SEER TD Range
    8 30 33
    10 25 30
    12 20 25
    13> 10 20
    Jan 2012
    Springfield,Il
    also then I know how to get the tonage how do you read the nominal seer on model#?
    Dec 2006
    Goodyear, AZ
    Standard ARI 210/240, Performance Rating of Unitary Air-Conditioning and Air-Source Heat Pump Equipment is at (80 degrees dry bulb, 67degrees wet bulb) inside air and 82degrees outside air for a single speed compressor and indoor fan.
    Quote Originally Posted by djustice75 View Post
    Not all manufacturers have the SEER rating in their model number.
    Forget about that X over outside ambient stuff for now. And use SC and SH to determine if a system is charge right, and or working right.
    Jan 2012
    Springfield,Il
    Talking
    ok thanks much appreciated!
