    Feb 2007
    Great Lakes Region
    Where should I post?
    Whats the difference between tech to tech and pro forum? It seems tech to tech always has the most viewers?
    Read the header at the beginning of each section an it will tell you if it is an open forum that can be viewed by all.
    a lot more imposters in tech2tech
    The pro forums, are closed forums. So only Pro members can view and respond. In the Pro forums you can be as technical as you want, in the open tech to tech. if it gets too technical, the thread will be moved to a pro forum. Prices are also allowed in the closed forums, but not in tech to tech.
    Tech to Tech, is a good place for new members to get their post count up and to aid the membership committee in determining if the applicant is in the trade.
