Results 1 to 9 of 9
    Jun 2012
    trane 3 ton compressor
    When ac unit runs, only the fan turns on. The compressor keeps trying to start, but it pulls 90 amps and immediatly kicks out. It does this continually.Does this mean the compressor is bad?
    Aug 2009
    Beatrice, NE
    maybe
    Jun 2012
    What could cause this?
    Quote Originally Posted by Jeffrobodeen View Post
    It could be one of several issues, low voltage, burnt wire, high resistance in contactor, bad start component. How do you know it is drawing 90 amps?
    Aug 2009
    Beatrice, NE
    A stuck compressor, bad winding, bad cap, burnt wire, bad contactor, system pressure not equalizing, low voltage, short cycle, hydrolock, to name a few.
    Jun 2012
    A friend who is an electrician checked the amp draw when it was trying to start!
    Call to have it serviced, and do not attempt to start system, further damage could alleviate a simple repair.
    Jun 2012
    Ok, thank you!
    Virginia
    Fixed 3 units doing that exact thing today its the season for that part to fail ,call your service company
