Results 1 to 8 of 8
    Jan 2012
    Amana Control board issue
    Did i service call for no air blowing got up in the attic and checked the board. I would press the door switch and i would hear a click red light then nothing... I could hear the lines going which mean the condenser clicked on... but no blower.. im getting all the voltage i jumped the R and G and no fan... normal operation would be a steady red blinking light but nothing. Just one blink which means SYSTEM LOCKOUT (RETRIES/RECYCLES EXCEEDED) what do i need to do??
    May 2011
    Ripley, WV
    Can you get pro status? I want to help but don't want a DIYer to read our discussion and fry themself.
    Last edited by Rob_in_WV; 06-28-2012 at 11:35 PM. Reason: Didn't realize I wasn't in the Pro's forum.
    Jan 2012
    Lol I'll do it in the morning. Im getting ready for bed. Thanks for the help
    May 2009
    oklahoma
    You could try wiring the motor to run direct to see if it works. Would also check your limit switches.
    May 2009
    oklahoma
    Also try wiring around the door switch temporarily
    Calgary, Alberta
    Did you try turning the fan wheel by hand? Check the run cap? Ohm out the run windings? Check for line voltage at the speed taps on the board?
    Jan 2012
    Yes I did all of it I couldnt get a jumper to bypass the door switch
    Jan 2012
    Forgot to mention it was a variable speed
