    Nov 2002
    Honeywell thermostat removal from wall
    I have a round Honeywell thermostat from about 1970. It is for both heating and air conditioning. It works just fine. I have to remove it from the wall to replace the wallpaper behind it. Mechanically, how do I remove it please? I don't want to start unscrewing screws without knowing which screws to remove.
    Thanks, Henry
    Apr 2012
    winnipeg
    three screws ...... post a picture we will tell you
    Nov 2002
    Do the three screws look like they are flat heads and are slightly below the subbase?
    Thanks, Henry
    I'd get rid of that old mercury thermostat, and get a new one.
    Mar 2009
    Mount Holly, NC
    honewell still makes the round design thermostat. in digital form. google search for them.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
