Results 1 to 13 of 36
    Jun 2012
    Trane XL 16i 5 Ton installed yesterday
    I just had a Trane XL 16i 5 Ton installed yesterday, and I don't think my installer used the right vapor line size. The installation manual says to use 1-1/8 vapor line and I have what I think is a 3/4 inch line. Will this make any difference in performance, efficiency?
    Should I ask him to use the correct vapor line size?
    Thanks for your reply
    Apr 2012
    winnipeg
    1- 1/8 for what length of run..... 10 feet different than 60 ...
    Jun 2012
    I think it is probably somewhere between 10-15 feet.
    Thanks for your help
    Apr 2012
    winnipeg
    I would of installed 7/8 ..you will be fine in my opinion
    Jun 2012
    ok. Thank you. Do you think the smaller line would compromise my new systems ability to cool the house? I paid more $ for a 16 SEER and want to be sure I get what I paid for.
    Also, do you know what temperature the air coming into my house should be (about)?
    Thanks - you have been very helpful.
    Apr 2012
    winnipeg
    your suction line is fine.... you should have between 15 and 18 degrees difference from return to supply.....
    Quote Originally Posted by Wabey View Post
    Your line size should be 7/8th and 3/8th
    with a maximum length of 80 feet and a max vertical lift of 25 feet.
    What is the document # that you read 1/1/8th for the suction?
    Jun 2012
    Its in the Installer's guide (Trane) 18-AC86D1-4 for Condensing units 4TTx6.
    Ok. A dumb question...how can I easily measure vapor line diameter (for a newbie)?
    THanks
    Apr 2012
    winnipeg
    measure the o.d. of the pipe .... callipers come to mind
    Lancaster PA
    Wabey, Made this its own thread. Your not allowed to post in other peoples threads in the AOP forums.
    Suppy NC
    to answer the op question
    you will lose btu output of the unit i tend to think about 3 to 4 thou but
    you eff will be the same for the most part
    i would recomend you have them increase the size of the lines to 1 1/8 / 3/8
    so you will get the most of your unit when all of its output is needed
    Jun 2012
    beenthere!
    My apologies. I could not find how to post new thread....but everyone has been very helpful! Very
    Apr 2012
    winnipeg
    oh man ...... 7/8 is plenty ....where you pulling this info from..... cause it is wrong
