    Jul 2005
    Tulsa
    Making up Pro Vacuum Pump Tree for Cheap
    Helps if one has a stash of fittings.
    if not visit here for an idea of what fittings are available. http://www.centurytool.net/Flared_Tu...gs_s/37883.htm
    Here I'm putting together a 3/8in Tree adapter for a 6 CFM Robinair with 1/2in flare. Instructions are the same for putting together a 1/2in tree. Use a four way flare fitting for an extra port. All sorts of combinations easily achieved with this simple/strong/cheap $$ design.
    1. cut 3/8in copper to desired length
    2. Flare ends
    3. You'll need two core removal tools. one with fitting for micron gauge and 1/2in flare to 3/8in adapter.
    Robinair on left, C&D Valve on right
    4. Fin .. black 1/2 hose and yellow 3/8in hose on top, both with 3/8in fittings.
    Jul 2005
    Tulsa
    double flare fittings are handy keeping your large hoses clean. note double flare fittings are available stepped.
    Athens, Ohio
    Double flare fittings! Doh! I bought flare plugs.
    Aug 2009
    Peoria IL
    Works for me have you put the vac gauge to it yet?
    Jul 2005
    Tulsa
    here's the initial test with fitting only.. 47 microns
    pulled a system down to 335 microns with 1/2in & 1/4in hose in about 10 minutes.
    test with 2x 3/8 hoses .. 100 microns
    Aug 2009
    Peoria IL
    looks great
