Results 1 to 10 of 10
    Jul 2010
    Malaysia
    30RB080 air cooled chiller
    Hey Guys,
    i am using the 30RB080 air cooled chiller.....How do you guys run the fan motor in full speed? i have totally modified my chiller into DOL start and stop system and i am stuck in testing the fan motor....It seems it need a PCB board to give contact it to run at full speed? Anyone has overcome this issue....Please get back to me ASAP as i am urgently requiring some answers
    thanks
    made this its own thread, and moved it to the open chiller forum.
    May 2002
    Not sure what you mean by "DOL"...please spell it out
    The fan motor...is it connected to a motor master 5 or in other terms a small variable frequency drive?
    Does this have comfort link controls ?
    If the fan is connected to a vfd or MM5 the controls supply an output to ramp the fan(s) up or down ... In test mode these fans won't necessarily run at full speed.
    I wish I could help but need more info...
    mikeacman
    Greenville SC
    The fan motors are controlled by the Fan Board. You shouldn't need any extra boards to make them run. If you are trying to test the fans operation in the test mode, and you have a VFD, then there are two imputs in the test mode. Pick the fan you want to test then turn in on. Then scroll down to the first setting below the fans, and imput your fan speed for the VFD. I'm not sure what you mean by DOL either.
    The Hot South
    Please tell us what you mean by DOL.
    A land down under
    Quote Originally Posted by R123 View Post
    R123, DOL (Direct on Line) is another terminolgy for Across the Line starters
    The Hot South
    Smile
    Quote Originally Posted by Screwit View Post
    That must be a down under term.
    Jul 2012
    TX
    You should be able to go into test and use the VAR_A command to ramp the fan up.
    A land down under
    Yep, Down under, NZ, Asia and I think Europe, petty much everywhere except the Americas
    Mar 2011
    Long Beach, CA
    DOL. I just learned something new.
    _______________________
    Understand the symptoms and you will find a solution.
