    Jun 2012
    AC/Furnace question
    I live in an apartment. If the AC and blower are being replaced and the furnace is a fedders from 1973. Would replacing the actual furnace help with the cost of the AC during the summer?
    Mar 2006
    The South
    Yes, if you go with a furnace that has either a high eff blower motor or var speed blower motor paired with a high eff matching condenser and evap coil.
    If not replacing furnace which I think you should consider based on age alone, then stick with a good basic 13 SEER AC or HP condenser with matching evap coil.
    IMO
    Jun 2012
    Confused
    Apparently something is very wrong because our thermostat is set at 71 but its 77 in here. They will not be replacing the furnace. Could an old furnace cause an outrageous electric bill.
    Quote Originally Posted by tabayer View Post
    Slightly higher bill. but should not be the cause of outrageous bills.
    Jun 2012
    Frown
    Ok. Thanks. Because we live in a 650 sq ft apartment and our bill was 200 last month
    Probably more from an old inefficient condenser, then from the indoor fan.
