Results 1 to 10 of 10
    my programmable stat could adjust the amount of cycles per hour, I have it set in the winter so that it cycles enough per hour that it'll stay on low fire. but I suppose it's less efficient on my a/c if i do the same for it. any opinions on this? thanks
    In cooling it may provide better humidity control running longer on first stage.
    2 stage A/C's are designed for long run times in first stage.
    only my furnace is 2 stage, my a/c is single...
    so, i guess if it runs longer periods; i'll get more dehumidifying value, as well save on the higher amps of the comp. starting up.?
    Re: only my furnace is 2 stage, my a/c is single...
    Yes.
    If your furnace has a VS blower, a humidistat can be added to control humidity, and allow for higher air flow when the humidity is down.
    Giving you a higher sesible capacity once the RH level is reached.
    Huntsville,AL
    most rotating machinery rated for not more than 4 starts/h -- check with the mfgr of your compressor --
    thanks guys n/p
    Rochester, MN
    Sel, Do you have a two stage t-stat?
    You want long run time not, short ones.. 3CPH is good on both heating and cooling.
    just a single stage, haven't considered the 2 stage yet. just put in the a/c. but you got me thinking, wouldn't be a bad toy.
    Rochester, MN
    A two stage stat will be MUCH better and more comfort in the winter.. It will advoid the furnace going into 2nd stage on a timer. The stat will only run 2nd as needed.
    Make sure you have a dealer do the t-stat, that way they can set the board up to a two stage stat vs a timer.
