Results 1 to 13 of 13
Thread: RTU smokie
    RTU smokie
    Reefer guy here but saw this and it interested me. The first 2 pics are one unit and the second 2 pics are another unit. That PVC goes to a smoke detector inside the blower compartments and, as you can see, the pipe terminates at the drains. There is an additional smoke detector in the blower areas that are tubed the way I'm used to seeing them. What is being accomplished here??
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	272531   Click image for larger version.
ID:	272541   Click image for larger version.
ID:	272551   Click image for larger version.
    never seen that done before
    no clue what they thought they were accomplishing
    Jun 2006
    New Jersey
    Waterless condensate trap?
    Sent from my C771 using Tapatalk 2
    Jun 2012
    Lynchburg, VA
    In the first two pictures, the lines connected on the back side of the unit aren't even serving as a drain.
    I've got no ideas except for the installer had extra PVC and didn't know what to do with it - or it's a means to equalize the pressure in the condensate line to eliminate a trap.
    NH
    Looks like a plumber installed it.
    Apr 2012
    winnipeg
    I have never sen such a thing.....
    Dern, was hoping this was some kind of new thing, or some plausible explanation.
    Jun 2006
    New Jersey
    Waterless traps.....
    http://www.trenttech.com/product_overview.html
    Oct 2001
    on a 100F day and a bird lands on top of the PVC riser pipes...snap the manufacturers spend millions of dollars keeping units weather tight. if any PVC is on the negative side of that supply fan they are going to suck rain water into the ducts... the typical trap is right below the fan access panel or coming out from the below that OA hood..that is a power exhaust for sure...maybe that's the piping show needed
    "when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
    Jun 2012
    Lynchburg, VA
    Nice find ascj
    Feb 2012
    New Jersey
    that is crazy i have never seen anything like that and honestly never saw or heard of that before
    I see it now & again. I never knew why they were set up this way
    Sent from my HTC Sensation 4G using Tapatalk 2
    Thanks, ascj
