    Nov 2005
    commmon to start then common to run then run to start. if common to start is 1.5 then run to start is 2.5 common to run shoukd be around 4? is this correct?
    no
    http://www.hvacoracle.com/cgi-bin/pu...=306&s=cooling
    quote from this site
    "The ohm reading on the run winding between R to C read be the lowest ohm reading, the start winding S to C will be the next higher, and the S to R which is both the run and the start reading will be the highest and should be equal to the sum of the other two.
    I.E. Run winding C to R =2 ohms, S to C =6 ohms, and S to R = 8 ohms."
