Results 1 to 2 of 2
    Nov 2009
    Oakland County Mi
    refrigeration piping underground
    I have a job that the refrigeration pipe was installed in a crock, and there is a leak underground. My question is, after the repairs are made is it still legal cover the pipe. Or do I have to run new refrigerant lines above ground to they can be repaired next time. This is a 150 ton chilled water system, with the condensing unit outdoors and the chiller barrel inside. The pipe length is about 65'.
    Thank you
    Gem6376
    Michigan
    Lancaster PA
    They can remain underground.
