    compressor replacement
    I am to replace a compressor for a true freezer. Can I buy compressor with the same HP, Voltage, and use the same type of refrigerant?
    Jul 2000
    Treasure Coast/Florida
    Who is the compressor's manufacturer and what's the model number?
    A direct replacement will be available from any supply house which handles that manufacturer's compressors.
    May 2010
    This sounds like its going to turn out disastrous :P Please call a pro, and no, you cannot use plumbing solder
    Quote Originally Posted by koolerdude View Post
    I suppose that would be better than one that has a different HP, voltage, and refrigerant
    Jan 2010
    koolerdude,
    Have you ever changed a refrigeration compressor before ?
    Jan 2010
    Quote Originally Posted by craig1 View Post
    koolerdude,
