Results 1 to 13 of 19
    NW burbs of Detroit
    I bought a Turbo Torch flow regulator
    And the scale is 10 psi to 75 psi.
    I flow at 2 psi...how the hell you supposed to read 2 psi when the smallest graduation is only 10 psi?
    Do they make flow regulators that are graduated in 5 psi increments?
    And since i am using Dry Co2 my regulator hose connection in on the bottom of the regulator...my flow reg would need a flare 90* to mount up right.
    Am I on the right track wit the 90* flare or is there a better way?
    Quote Originally Posted by hvaclover
    Set the reg with yer fancy-pants SuperMAN gauge....
    Oct 2011
    Arkansas
    Quote Originally Posted by hvaclover View Post
    I'm using a swagelock needle valve with a regulator on one of my rigs. Still waiting on John Stone for my Turbo flow meter. Must be why they had them for $30, they're worthless.
    90 degree flare should do the trick.
    NW burbs of Detroit
    I would not dream of putting CO2 tru ANY manifold.
    Except maybe a DIGGI QUEEN....can I borrow yours JP?
    NW burbs of Detroit
    I found a low resolution flow meter...but it's for "GROWING" wacky-weed lol!
    I can understand your reluctance to introduce a compound like that to such a fragile instrument as your SMAN.
    You're welcome to use my DC anytime you're around, but I'll never part with my DC.
    On a serious note, WHY NOT?
    NW burbs of Detroit
    Cause I blew up a lot of Compound gauges in the past...over pressure.
    Just won't make that mistake again.
    I also just bought a turbotorch flowmeter, but mine dont have PSI it has SCFM (standard cubic feet per Min). I was told to run it about 5 SCFM
    http://www.thermadyne.com/turbotorch...odID=0386-0849
    NW burbs of Detroit
    Yeah but your using Nitro...I am using Dry Co2....2 scfm is standard for co2.
    You get pinholes if you use a higher flow rate.
    If your flow meter reads in PSI, you bought the wrong kind of meter...
    las vegas
    Quote Originally Posted by AC5096 View Post
    the on from j stone is great when you get the correct fittings to keep it up rite.
    you dont need to run in psi checked mine against my testo 510 earlier & im
    purging at 7 in. w,c. could probably even go lower. just get the
    ball floating & your ok. on my mig machine i only run 5 psi for a shield &
    with argon it is plenty.
    NW burbs of Detroit
    It reads in SCFM....
    Oct 2011
    Arkansas
    Quote Originally Posted by marvin View Post
    I read somewhere around 3 scfm. I guess I'll find out if I ever get one. Johnstone has them on backorder.
    My Air Products regulator has the outlet a 3 O'clock. I shouldn't need any extra fittings to keep it upright.
