Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 83
  1. #27
    Apr 2010
    working overtime
    h10 styles
    Is the h10pm easier to use than the h10 p which I think is the one I have. It's the old 115b plug in style and you have to dial it in and very hard to get set right on small setting.
  2. #28
    Jul 2012
    Christchurch, New Zealand
    I also have been having a hard time finding small leaks with my H-10. I am looking at the Fieldpiece infrared SRL2K7. I dont know anything adout it but it uses a different technology.
  3. #29
    Jul 2005
    Quote Originally Posted by heaterman54 View Post
    I've had a hard time getting used to my fieldpiece.
    The Bill of Rights ARTICLE II "The Right of the People to Keep and Bear Arms Shall NOT be Infringed".
    [SIZE="4"]
  4. #30
    Jun 2012
    The Woodlands, Texas
    I have had ZERO problems using the H-10 on 400 series blends.
    I don't have a lot of experience with R410a in particular, but I've found a LOT of 402a and 404a leaks along with 134a, 407a, 507 and other HFCs.
    The H-10 works great on R12, R22, and R134a.
    Some of the 400 blends have 134a in them.... R410a does not.
    The H-10 does well on 400 blends that have 134a in them.
    From my experience, it does not do well with R410a.
    From my experience, the new IR detectors work amazingly well on R410a. They are extremely sensitive and very consistent.
    I have had good results with both the Fieldpiece SRL2K7 and the D-Tek Select.
    Just my two cents.
    Tony
  5. #31
    Jun 2012
    Quote Originally Posted by nratom45-70 View Post
    The new IR detectors take a little time getting used to... Especially if you have been using a heated diode detector for a long while.
    I was a little frustrated at first but I read the manual and followed it precisely. After a few weeks, I was getting better and better with it. Now it is like riding a bike.
    Tony
  6. #32
    Jul 2003
    Fort Worth, TX
    Quote Originally Posted by atoreson View Post
    Tony
    As a big cheerleader for H10G, we have had issues with 410a. I just got the Fieldpiece SRL2K7 and have yet to use it on an HFC, but it worked well on 22. It is going to take time to get used to constant movement and not trying to pinpoint a leak by leaving it stationary, it will recalibrate and not go off.
    Not that I have done this, but a squirt of 22 into a 410a system makes leak testing MUCH better with the H10G.
  7. #33
    Apr 2010
    working overtime
    I have had a harder time with 404 than 410 I love my h 10 never had problems finding leaks but time of problems with the d tek. I didn't like the fieldpiece that a co worker had but i havrny had much luck with any fieldpiece products. They make tons of diffrent ones it just comrs doen to what works best for you. We all do yhings a lurked diffrent so what works for one may not work for another
  8. #34
    I really like my tif-zx ,but something made my life miserable because It was picking up a some insulation and I end up changing a line set, I just brought a h-10g for $150 on eBay , is it a good price?
  9. #35
    Apr 2010
    working overtime
    150 for a h-10 is a great price. I paid much more than that. If its used I would reccomend you send it to be refurbished. It costs like 100 bucks. One thing I didn't know for a long time is on the bottom of it there is a sensitivity setting I turn mine to highest setting
  10. Dislikes johnnymick disliked this post
  11. #36
    little hocking ohio
    Got my first h10 in 1975 next one the green one in 1996 when I worked for Scott polar still have it. Retired 5years ago. Hated the new refrigerants,give me the 12,22,502 any day. Just an old man talking.
  12. #37
    Dec 2003
    Citrus County, Florida
    The Fieldpiece SLR8 works well with R410. It is not to good on R22. It is a heated diode type and uses sensors every couple of years depending upon usage. The new H10's are super-sensitive for R410.
    Doug
  13. #38
    Nov 2008
    Bristol Va.
    Quote Originally Posted by Gunslinger View Post
    supposed to be the same sensor in all of the H-10's.
  14. #39
    Jan 2014
    Northwest Ohio
    H-10PM killed my Dtek
    I think I have read every post about the H10 on this site. I personally have the H10PM. I traded a D-Tek select for it becuase the Dtek couldn't find a leak in a leaking 410a unit. Another Tech came out with a older H10G and found the leak that I had spent seveal hours searching for in less than a few minutes. Of course this is after I just got done making fun of the H10 for being old technology....ouch that hurt! I replaced the battery with a new matched up battery from the Internet for around $18 delivered. Put a new sensor in it and calibrated it per the instructions and haven't had any problems with it. I charge it every night after I use it that day. Use the low sensitivity for hfc's and med for r22. Another funny thing to mention is the Dtek will not pick up the calibration gas of the H10. Mmm, wonder why.....lol
    Last edited by ucantstopthis1; 08-13-2016 at 04:47 PM. Reason: Left out a few words.
