Results 1 to 6 of 6
06-22-2012, 09:58 AM #1
- Dec 2011
- birmingham, al
- 6
mitsubishi lm adaptor integration
Has anyone integrated the mitsubishi with a jace (trend TONN6)? Im having some problems with this system.
06-23-2012, 01:32 PM #2
- Oct 2007
- England
- 144
I have not done a Mitsubishi integration but have done a few others.
I have worked with Tonn,Hawk & Jace. I may be able to help.
What exactly is the problem?
06-23-2012, 09:24 PM #3
- Dec 2011
- birmingham, al
- 6
We have done daikin and Sanyo, but this our first Mitsubishi. I just can't pull in any points and the lm adapters keep freaking out, and Mitsubishi tech is about terrible in helping out.
06-24-2012, 03:35 PM #4
- Oct 2007
- England
- 144
Have a look at the Lonworks help file in workbench.
It has some usefull pointers to the 'Lon Utilities Manager' this may help you identify a timing issue perhaps.
Also have a look through the 'About Lon Network Architecture' in the same help file. There are some good pointers in this which may help you.
I take it that you can see the devices on the lon network when you do a learn. but then you cannot discover the Nv's & Nc's of each device.
Do you have a lon adaptor in your laptop? if so then try and run up a station on that and connect locally, try the learn process again. If it works then it could point to a wiring issue.
Just a few thoughts.
Keith
06-25-2012, 09:23 AM #5
- Dec 2011
- birmingham, al
- 6
yes, you are 100% correct. I did that over the weekend and got all my points pulled in and everything working correctly. Thanks!!
06-28-2012, 12:47 PM #6
You may want to look at this site as well to make sure. I just did one and I was able to see everything but to prevent local setpoint control and scheduling the documentation is essential.
http://usa.mylinkdrive.com/categorie.../show/538.html
It is the Mitsubishi Site for their LON interface.You can easily judge the character of a man
by how he treats those who can do nothing for him
-James D. Miles
