Page 1 of 4 1234 LastLast
Results 1 to 13 of 51
    Jun 2010
    jersey
    Trane Voyager rooftop poopie
    Heyo..
    im working on brand new rooftop.. first stage cooling well.. when i installed system i ran unit thru test mode ..ll was well.. now i think it has been finally put in 2nd stage for the first time other than startup.. RESTRICTION .. compressor ****s off so fast , i cant test for clog by temp..hopefully its in L.L dryer .. cause otherwise.........
    So anyway.. now trane wants me to put in a retro kit that has a txv....but thats changing he coil .. something i want to avoid...at all possible.
    Im on the fone with trane the day after ... and guess what .. units out again . ( at least thats the call i got.. i took coil contacts off the 2nd stage so it wouldnt kick the breakers aanymore) now im onmy way back down there..
    that ws more a lil venting.. my question is related o my control systen.. i have trane rover 4.2.. with that varitrac touch screen controller.. when im trying to test it out i cant find anyway to start system in 2nd stage... anyone know ?how?? . other than starting it and dropping all the zone sensors very low..?? thanks
    Apr 2012
    Paper Street Soap Company
    With or with out Trackeryou should be able to test it.
    There should be a board with conventional thermostat hookups.
    Isolate Tracker and run a short multi conductor to R, G, Y1 and Y2
    Jun 2010
    jersey
    thanks for quick reply...
    i meant cant let you do it fromthe controller... thares no option for it .. or stage 2 heat either.
    Quote Originally Posted by WorkHardThenDie View Post
    What is the model #
    Jul 2011
    East coast USA
    I had a new RTU 2nd stage doing the same thing on a first time startup. Thought it was TXV or drier. changed dryer. worked for a bit than same issue. I checked around found that this drier had issues in the past..-bad batch- changed drier again. ...all OK.
    My next step was the TXV glad it was the drier...
    Jun 2010
    jersey
    Frown
    ycd240f3haaa
    going there on sat to recover and try to blow out the lines... considering trane is going take forever on oems...
    how do they not even have a filter drier in stock??
    killin me
    Jun 2010
    jersey
    btw.. went back. unit running fine in stage one.... women in office complaing its only at 75 when we want 72........
    ITS 101 OUTSIDE! TAKE OFF YOUR PANTSUIT FATTIE!
    East of big city prices.
    ycd240f3haaa
    killin me
    Just get a non oem drier.
    Jun 2010
    jersey
    then warranty doesnt carry... first summer for this thing... my boss should be getting pain for my time and his aggravation
    Is that an R-22 unit?
    Jun 2010
    jersey
    no. r410a
    trane voyager reliatel system.
    installed over the winter.
    Feb 2011
    OH
    looking at manuel .place jumper t1 t2 2 contiuous seconds .allowing unit to energize ,the unit can now be scrolled through modes.when you remove jumper it will stay in that mode 1hr . if you need more info, . Email addresses are not permitted in post. ,I hope this helps used this lots of time . education through knowledge.
