Results 1 to 13 of 51
Thread: Trane Voyager rooftop poopie
06-21-2012, 02:41 PM #1
- Jun 2010
- jersey
- 86
Heyo..
im working on brand new rooftop.. first stage cooling well.. when i installed system i ran unit thru test mode ..ll was well.. now i think it has been finally put in 2nd stage for the first time other than startup.. RESTRICTION .. compressor ****s off so fast , i cant test for clog by temp..hopefully its in L.L dryer .. cause otherwise.........
So anyway.. now trane wants me to put in a retro kit that has a txv....but thats changing he coil .. something i want to avoid...at all possible.
Im on the fone with trane the day after ... and guess what .. units out again . ( at least thats the call i got.. i took coil contacts off the 2nd stage so it wouldnt kick the breakers aanymore) now im onmy way back down there..
that ws more a lil venting.. my question is related o my control systen.. i have trane rover 4.2.. with that varitrac touch screen controller.. when im trying to test it out i cant find anyway to start system in 2nd stage... anyone know ?how?? . other than starting it and dropping all the zone sensors very low..?? thanksLast edited by WorkHardThenDie; 06-21-2012 at 02:43 PM. Reason: typing on my fone
06-21-2012, 02:53 PM #2
With or with out Trackeryou should be able to test it.
There should be a board with conventional thermostat hookups.
Isolate Tracker and run a short multi conductor to R, G, Y1 and Y2
06-21-2012, 02:58 PM #3
- Jun 2010
- jersey
- 86
thanks for quick reply...
i meant cant let you do it fromthe controller... thares no option for it .. or stage 2 heat either.Last edited by WorkHardThenDie; 06-21-2012 at 03:00 PM. Reason: still on my fone.
06-21-2012, 03:20 PM #4
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
06-21-2012, 03:28 PM #5
I had a new RTU 2nd stage doing the same thing on a first time startup. Thought it was TXV or drier. changed dryer. worked for a bit than same issue. I checked around found that this drier had issues in the past..-bad batch- changed drier again. ...all OK.
My next step was the TXV glad it was the drier...
06-21-2012, 05:47 PM #6
- Jun 2010
- jersey
- 86
ycd240f3haaa
going there on sat to recover and try to blow out the lines... considering trane is going take forever on oems...
how do they not even have a filter drier in stock??
killin me
06-21-2012, 05:51 PM #7
- Jun 2010
- jersey
- 86
btw.. went back. unit running fine in stage one.... women in office complaing its only at 75 when we want 72........
ITS 101 OUTSIDE! TAKE OFF YOUR PANTSUIT FATTIE!
06-21-2012, 06:04 PM #8
- Jan 2008
- Dallas ,Texas
- 3,507
06-21-2012, 06:12 PM #9
- Jun 2010
- jersey
- 86
then warranty doesnt carry... first summer for this thing... my boss should be getting pain for my time and his aggravation
06-21-2012, 06:33 PM #10
- Jan 2008
- Dallas ,Texas
- 3,507
06-21-2012, 06:38 PM #11
- Jun 2010
- jersey
- 86
no. r410a
trane voyager reliatel system.
installed over the winter.
06-22-2012, 11:35 PM #12
- Feb 2011
- OH
- 148
looking at manuel .place jumper t1 t2 2 contiuous seconds .allowing unit to energize ,the unit can now be scrolled through modes.when you remove jumper it will stay in that mode 1hr . if you need more info, . Email addresses are not permitted in post. ,I hope this helps used this lots of time . education through knowledge.
06-23-2012, 07:42 AM #13
