Page 1 of 5 12345 LastLast
Results 1 to 13 of 55
Thread: QUAD??
    Curtis, Nebraska
    Here is my Idea of 16 tons of cooling and almost 400,000 btu of heating . All heat pumps and 93% furnaces
    cplt48 and gms9090 variable speed furnaces. My supplier said you could not twin the furnaces with heat pumps SO I QUADED THEM!![/URL]
    ALLRIGHT BOYS TEAR IT APART!! LOL replaced two 200,000 furnaces with standing pilot and no ac units and sold them on 4 heatpumps!
    [Edited by huskerdu on 07-26-2006 at 12:50 AM]
    There is no off switch to the genius mind!!
    Motors run on smoke!! When the smoke comes out of it, it needs a new one!
    Rochester, MN
    YOu used the small pix. Post a larger size.
    Yea, I didn't bring my magnifying glass
    I thought you weren't supposed to twin or quad ECM units?
    Mar 2006
    OK
    OOOO, OOOO, OOOO, I wanna see! Darn I can't quite make that out. Larger picks please.
    Never knock on Death's door. Ring the bell and run, he hates that.
    Views expressed here are my own and not neccessarily those of any company I am affiliated with.
    chicago suburbs
    what is up with that stat wire?
    FILL OUT YOUR PROFILE!!
    Curtis, Nebraska
    Curtis, Nebraska
    ok lets try this
    condensers/heatpumps
    Curtis, Nebraska
    More Condensers/Heatpumps
    other side
    SE Michigan
    They look too close together. Seperate disconnects would be nice too.
    Did you know those are Goodman units?
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    chicago suburbs
    Goodman?? on the wall of pride?? WHAAAAA?!!?
    Curtis, Nebraska
    Another angle of the outdoor units
    There is more room between them than it looks you can
    walk between them
    That box on the wall is an outdoor panel with breakers for each unit
    Curtis, Nebraska
    back to back gms9090 variable speed units
    Curtis, Nebraska
    solid state relays for each connection from the thermostat
    I am amazed each time the furnaces fire it is like a symphony identical timing on the heatpumps and the backups.
    The supplier said it would not work but I installed these last OCT. and have never looked back. they have been very reliable.
    Had to think a while before posting because I knew I would catch grief, but the only thing I can say is IT WORKS GREAT!! This is in a theatre that is owned by the community and run by voulenteers nice set up!!
