Results 14 to 19 of 19
    Sep 2011
    You can use your recovery machine to charge a system? Any tips?
    Jul 2005
    Jul 2005
    Quote Originally Posted by wdshea View Post
    Sure. Connect your refrigerant cylinder to the inlet of the recovery machine and connect the outlet of the machine to the unit. Turn the recovery machine on and start pumping. Don't forget to purge the machine and hoses first. And don't try to force the refrigerant through a shrader valve unless you remove the core, cause it won't work.
    Mar 2009
    Mid-Mo
    It's the only way to go when you have 50+ pounds of gas to put in. 3/8" charging ports and bigger are awesome.
    Sep 2011
    And chrge with liquid?
    Jul 2005
    Yes, into the high side.
