06-20-2012, 08:52 PM #1
- Jan 2012
- 101
Pulling points from two JACE to Supervisor (FX Server)
Has anyone encountered a problem where trying to pull points from a particular device (FX16) that is connected to JACE-1 displays an error message, while pulling points from a network stat (different brand) on the same JACE-1 works?
I am trying to try a different approach whereby I expose my FX Server for remote access, rather than a JACE connected to another JACE (This lead to low java heap, and lots of problems). I have successfully setup my Server and can remotely access it. I am able to add both JACEs to the FX Server via the Niagara Network.
I am successful in discovering the points, however, when I highlight and "add" the point, it displays an error message. I try the same thing to the network stat, and I can add it without any problems.
Here is the error message that occurs:
javax.baja.naming.SyntaxException: Invalid ord char 0xba
at javax.baja.naming.BOrd.parse(BOrd.java:353)
at javax.baja.naming.BOrd.resolve(BOrd.java:239)
at javax.baja.naming.BOrd.resolve(BOrd.java:217)
at javax.baja.naming.BOrd.get(BOrd.java:193)
at com.tridium.nd.ui.BNiagaraPointManager.loadNodes(B NiagaraPointManager.java:347)
at com.tridium.nd.ui.BNiagaraPointManager$Controller. doAdd(BNiagaraPointManager.java:481)
at javax.baja.workbench.mgr.MgrController.doAdd(MgrCo ntroller.java:678)
at javax.baja.workbench.mgr.MgrController$Add.doInvok e(MgrController.java:657)
at javax.baja.ui.Command.doInvoke(Command.java:303)
at javax.baja.ui.Command.invoke(Command.java:273)
at javax.baja.ui.BActionMenuItem.doInvokeAction(BActi onMenuItem.java:153)
at javax.baja.ui.BActionMenuItem.doClick(BActionMenuI tem.java:166)
at javax.baja.ui.BMenuItem.mouseReleased(BMenuItem.ja va:412)
at javax.baja.ui.BWidget.fireMouseEvent(BWidget.java: 1145)
at com.tridium.ui.awt.MouseManager.fire(MouseManager. java:305)
at com.tridium.ui.awt.MouseManager.fire(MouseManager. java:279)
at com.tridium.ui.awt.MouseManager.released(MouseMana ger.java:115)
at com.tridium.ui.awt.MouseManager.process(MouseManag er.java:88)
at com.tridium.ui.awt.AwtShellManager.processMouseEve nt(AwtShellManager.java:543)
06-21-2012, 04:23 AM #2
- Apr 2012
- 84
It looks like there is a symbol 0xba (degree) in point's ord, which is not allowed.
Could you check this ord?
06-21-2012, 07:55 AM #3
- Jan 2012
- 101
These points are temperature points, but im not sure why this particular point wont work. The other point i was anle to pull from the network stat is also a temperature point. Does this mean i have to reprogram and remove the units? That doesnt sound very good.
06-21-2012, 08:04 AM #4
- Apr 2012
- 84
The ord (address) of the point should not contain degree symbol. The "units" facets could have degree F, it is not a problem.
Could you let us see the name of the point you are trying to import?
06-21-2012, 09:14 AM #5
- Jan 2012
- 101
pault, I am baffled, but I just logged into my system remotely to discover the points and screen-capture for this purpose, only to find out that I can now add the points over. I'm not sure what caused this to happen. I will have to update you once I encounter the problem again and screen-capture the issue.
Thanks for your help.
06-21-2012, 09:16 AM #6
- Apr 2012
- 84
Maybe some random bug. It happens.
