Results 1 to 11 of 11
Thread: Trane goes boom!
06-20-2012, 04:52 PM #1
- Jan 2008
- Ottawa, Canada
- 164
Trane goes boom!
Guess I know what I'll be doing tomorrow.
06-20-2012, 04:59 PM #2
Been there done that, I assume your combustion motor is fried as well. Do you have the most recent service bulletin for that scenario??
06-20-2012, 05:05 PM #3
- Jan 2008
- Ottawa, Canada
- 164
I knew there was a service bulletin at some point, couple years ago right? I called my Trane locally and he said replacing the combustion blower will end all my problems. Was that the fix, new combustion blower motor? I thought there was some sort of relay kit as well.
06-20-2012, 05:11 PM #4
Here you go, kit part numbers are included. I had to replace every board and both the high voltage and control wiring harnesses on the last one I did. Trane however came good for all of the parts because it was less than 5 years old.
06-20-2012, 05:13 PM #5
I also fused that transformer as there is no overcurrent protection from factory.
06-20-2012, 05:23 PM #6
- Jan 2008
- Ottawa, Canada
- 164
06-20-2012, 05:24 PM #7
Professional Member*
- Apr 2011
- Coastal Maine
- 565
06-20-2012, 08:03 PM #8
Replace that turd with some real equipment. Not that hard to stop after all.........
06-20-2012, 08:22 PM #9
06-20-2012, 08:34 PM #10
06-24-2012, 05:46 PM #11
- Dec 2004
- NJ
- 93
Sounds like your not sure how to proceed with the repair, just use the skill you know you have, jump in & learn from it.
