Results 1 to 11 of 11
    Ottawa, Canada
    Trane goes boom!
    Guess I know what I'll be doing tomorrow.
    Jun 2008
    Windsor, Ont.
    Been there done that, I assume your combustion motor is fried as well. Do you have the most recent service bulletin for that scenario??
    Ottawa, Canada
    I knew there was a service bulletin at some point, couple years ago right? I called my Trane locally and he said replacing the combustion blower will end all my problems. Was that the fix, new combustion blower motor? I thought there was some sort of relay kit as well.
    Jun 2008
    Windsor, Ont.
    Here you go, kit part numbers are included. I had to replace every board and both the high voltage and control wiring harnesses on the last one I did. Trane however came good for all of the parts because it was less than 5 years old.
    Jun 2008
    Windsor, Ont.
    I also fused that transformer as there is no overcurrent protection from factory.
    Ottawa, Canada
    Quote Originally Posted by nyrb View Post
    Thanks nyrb, I knew he was leaving something out when I called him. Will fuse it as well.
    Apr 2011
    Coastal Maine
    Ditto on that one.
    Afton, VA / Khorat, Thailand
    Replace that turd with some real equipment. Not that hard to stop after all.........
    Midnight Sun Astrophotography
    Jan 2011
    Boston, MA
    What size fuse do you use?
    Jun 2008
    Windsor, Ont.
    Quote Originally Posted by FrostyBeer View Post
    It's been a while but I think I fused the primary with a pair of 1 amp time delay fuses, this unit was a 600 volt model.
    NJ
    Sounds like your not sure how to proceed with the repair, just use the skill you know you have, jump in & learn from it.
