Thread: Trane ABTF leaking
06-20-2012, 01:35 PM #1
- Mar 2006
- NORTH HAVEN ,CT
- 87
Trane ABTF leaking
Looking for a little info .I'm working on a Trane ABTF absorber and one of the solution pumps is leaking out of the condensate weep holes in the motor housing . I never took one apart .I bought a rebuild kit which is a o-ring and 2 carbon seals . I was wondering were the solution could be coming from. Any input would be great .
06-20-2012, 06:06 PM #2
New Guest
- Apr 2011
- Midwest
- 2
If you are getting solution out of the weep hole, there is a leak in the motor "can". The motor is completely sealed. The solution flow around the rotor to cool the windings and lube the bearings.
06-26-2012, 08:36 PM #3
- Sep 2008
- Delaware
- 243
If you have solution coming out of the weep holes the motor is leaking. A rebuild kit will not solve your problem but can be used when you change the pump motor. As "Service Call' mentioned, the motors are "Sealed" in a Stainless Steel can that evidentaly has a hole in it.
Good Luck!
Been there, Done that
